script for set measured to nominal
  • script for set measured to nominal
    Hello for everybody.
    I'm looking for a script , what can be automaticly perform the " Operation-features-Reset measured values to nominals-all" command.
    Can anybody help about it , 'cause i don't hane too munch experience in VB
    Thanks in advance: Peppe
    I haven't got senility. knock on wood.. oooo ..who is there?sigpic
    What would you need this for? Special cases?
    if you plan on using it across the board, i think there is a setting in the settings editor that stops the program from auto saving after executing.
      . If i have a big different between the noms and measured value in the program (it comes the saved coordinate systems) , it can be make some trouble.( you can read it in the help file in tricks session) Before running the program , i need reset the measured to noms automaticly.
