Tempcomp/method
That's just a comment that was created because that temperature comp command isn't supported by that version of PC-DMIS. That will happen when you created a command and then back save to an older version that uses different code. You will need to insert a new temp comp command.PC-DMIS 2016.0 SP8
Jeff
by DeWain HodgeWe have only just started using xact measure for reporting and I confused on something I'm seeing and I don't know the answer for. On the attached screenshot...
05-19-2017, 12:10 PM -
by Donald M
Ok guys I'm stumped...
How should I measure this?
I need to measure...-
03-21-2018, 03:54 PM -
I don't know what I did to turn this on. How do I get rid of it?...-
03-13-2019, 08:29 AM -
by ohiocmmIs there a "cheat sheet" for shortcut keys. I have version 4.2.
Thanks.-
10-28-2009, 03:09 PM -
