I am currently working with 2019 R2 CAD ++ Offline and am having an issue with scanning. When I open up any of the scanning options and go into the cad controls I cannot select any surface but if I close out of the scanning option I can select the surfaces I am trying to select in the scan option. Has anyone seen this issue?
Scanning Issue
CAD Corrupted, You'll spend hours and get nowhere, Have your engineer to recreate it or export it in a different type of file, IGES, STEP, or whatever. You may not get it to work, unfortunately you may be screwed on this. This happens quite to often with me.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
- Likes 1
Originally posted by andrzejewski988 View PostI am currently working with 2019 R2 CAD ++ Offline and am having an issue with scanning. When I open up any of the scanning options and go into the cad controls I cannot select any surface but if I close out of the scanning option I can select the surfaces I am trying to select in the scan option. Has anyone seen this issue?Regards,
Krishna Chaitanya Velisetty
Metrology Software Applications Specialist,
Hexagon Manufacturing Intelligence.
Thanks everyone. I did have the select box checked and in DCC. I ended up getting it to work but did take a while. We use an external alignment so we bring our part models into Creo as a step and then export the part and alignment plate out as an IGES. I will try and bring the part models into creo as an IGES and see if this helps. Thanks!
by 2013_junkieSo first and foremost, I'm completely wet behind the ear with scanning. We have decided to add scanning to a few of our machines, so while we are waiting...
01-08-2018, 11:53 AM -
by FAMOUSX1Good Day Gents,
I am having an issue with scanning.
When I try to create linear open scan and I execute... it hits the part as points. ...-
03-10-2016, 01:03 AM -
by metalquest1I'm looking at adding scanning capability to one of our CMMs, and purchasing an SP600M scanning head to go on my PH10M. I'm currently running both PC-DMIS...
11-30-2010, 04:21 PM -
I am really struggling with scanning
I have a profile I need to scan on a recessed O.D.
I have tried all the different types of scanning...-
07-18-2019, 12:00 PM -
