Is there anything written in a standard that specifies how parallel surfaces need to be to each other to make a single datum plane? For instance; I have 4 separate surfaces that make up [A],
I know they can be at different heights and still create a Datum plane but per a STANDARD do they also have to be parallel or is there a max degree one or more of the surfaces can be out from the others
before it is considered technically unusable?Capture.PNGCaptionhttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
