in my report the analysisview is showing like it is in z- view and i need it to show in the z+ view. how can I get it to stay that way? I have tried rotating it but it always goes back to the way in the picture. confusing.
Can't get the analysisview to orient the right way in report
Perhaps someone will tell you how to make the graphical report on the measurement of profiles or roundness updated independently ? Until now, every time I have to delete a line from the program’s display code (otherwise it gives the previous graphical analysis), return to the analysis window and save it in the report.
you just need to do what SingularitY says above, without that command the analysis view will not update on the next part, do that and it will update
by PlasmaGuyI have a question about the analysis view. I've been trying to set up a view of a cylinder that consists of three circles. I can go in and rotate the...
05-11-2007, 10:54 AM -
by RANDYKHi Team.
Running 4.2 MR.1.
When I use insert report analysis view, I can rotate the view, set an ISO view or whatever. ...-
01-08-2008, 10:41 AM -
by TOMW.I'm trying to use the analysis view in the y-axis for circularity analysis on a part I've got
mounted lengthwise on the cmm table, but the analysis...-
04-07-2015, 02:36 PM -
by JackMido[incoherent ramblings of a man on the edge]
Does anyone have any tips for getting analysis view to work properly? I'm currently adding the analysis...-
03-01-2018, 10:11 AM -
by Jim PoehlerOut of the blue, pc-dmis has decided not to update the graphic display for analysis view in a recent program. I have never encountered that before, has...
05-24-2016, 05:00 PM -
