I tried searching for this with no luck, but in the software I use for our faro arm it will show me the actual alignment deviation from the part to the cad. When I run the cmm using PCDMIS I use a lot of iterative alignments for our parts, is their a way I can extract the deviation of the alignment and possibly even how many iterations it had to cycle through? I understand if I have a point target radius of 0.1 and a fixture tolerance of 0.1 then obviously everything is below that tolerance, but I just wanted to get the actual number.
Thank you.
Thank you.
