I am trying to take a measurement from the apex of a constructed 100 degree cone tangent to a measured sphere. I'll attach an image to give an idea of what I'm tryin g to do. Can this be done in PC-DMIS? Capture 6-365.PNG
Construction help
I am trying to measure the "10.744" dimension in the picture above. The blue lines are constructed and are not measurable features.
Thanks
I would recommend doing this using several 2D evaluations. You can take a line on each side of your cone and then click Insert> Feature> Constructed> Circle. From the dropdown select "Tangent 2 Lines". Key in your gage ball diameter and dimension the circle to the cone vertex, add radius. I would also recommend doing this at a minimum in both X and Y workplanes
You can do it by a little trig, from the sphere center (If the cone is aligned on the sphere center, it's a 2D problem between a line and a circle).
So the line is at 50° (half angle), so the radial line is at 50°.
The contact point between the line and the circle is Rcos 50 on X and R sin 50 on Z.
Then the cone vertex is (5cos50)*tan(40) + 5sin 50 on Z from the sphere center.Last edited by JEFMAN; 06-14-2021, 07:45 AM.
- Likes 1
by mdobb829I have a Pallet that has (4) cones. There is a dimension from the bottom of the Pallet over an Ø85.000 MM gage ball. Is there a way to create the gage...
06-25-2016, 06:37 AM -
guys. i'm measuring a taper and need a diameter from a gage point .039 down from top surface. i have a plane perpendicular to the cone. how do i derive...
05-27-2010, 07:51 AM -
by FMC.QCI have a cone that is being checked with gage balls tangent to the cone and the plane. Is there a way to measure my cone and the plane, then insert theoretical...
02-26-2014, 04:46 AM -
by LondonjrI am trying to determine the best way to figure this 1.1417 length over a gage diameter. The length is called from a plane set at .944 gage diameter...
04-20-2016, 08:25 AM -
by PowerJunkieI've got an angled step in the I.D. of a cylinder that I'm trying to measure.
I've tried various methods like probing 3 set's of lines...-
11-09-2007, 04:51 PM -
