There's a customer we deal with who has some pretty odd shaped sheet metal parts, I created a program ran it, everything looked pretty normal, tolerances weren't on the high end especially for profile call outs, I proved it out 3 times, I don't see an issue with the program. This said customer is stating when they run the same parts they get better results, than what were giving them, I asked okay are you using the same setup we are, the answer was yes. Beyond that I could think of a plethora of reasons that would have results vary, model of cmm, what does the cmm calibrate at compared to ours, what tips are they using, are you aligning per the datum's so on and so on. Funny thing is when we ask these questions they don't want to give answers or show their reports to us, so even though everything is well in tolerance I figured I'd ask you guys who have been doing this a while what variances can their be in a situation like this for this to happen other than what I stated? First time ever dealing with a issue like this, the only thing is the part has a slight angle for the primary plane so maybe they constructed a perfect theoretical plane for their primary datum, or the software I currently have is 2015 dmis, I know they are on 2020? I could see that maybe helping a little, but looking for your guy's thoughts on this?
Thank you.
Thank you.
