Renishaw HCU1 Pocket Terminal
  • Renishaw HCU1 Pocket Terminal
    This is the handheld box that allows you to manually change your angles on your probe head. Mine is not working. I have been told that the box is in "AUTO" which is why it will not allow me to use the A and B buttons to rotate the probe to a desired angle. Apparently, there is a setting for this in the settings editor, but I cannot find it. Anyone familiar with this?
    On mine if you are running in dcc at the end the hcui box will not work.If you press the enable button on the joy stick box then it works.
      I will give that a try.
