I have 30 pockets on a part that need width, length, parallelism,and perpendicularity checked on each pocket. However I only need to report the min and max for all 30. Is there a quick way to report the min and max on a group of dimensions other than exporting them to a spread sheet. I need to do this on 150 Parts.
Min Max of a group of dimensions
you could easily assign min/max of each pocket to variables, I'm not following if you want to report min/max for each pocket or only the smallest min and largest max value among all 30?
Try this..
Measure your stuff, report dimensions you need, capture those dimensions in an array, create a variable that finds the highest of each array, create a variable that finds the lowest of each array, assign the created variables to generic features (I chose circles) so the variables have somewhere to go, report the six circles. You can name your variables anything you want, I try to be pretty specific with my names so I can debug later if needed,
Code:PLN1 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<0,0,0>,<-1,0,0> ACTL/<0,0,0>,<-1,0,0> TARG/<0,0,0>,<-1,0,0> ANGLE VEC=<1,0,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN2 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<1,0,0>,<1,0,0> ACTL/<1,0,0>,<1,0,0> TARG/<1,0,0>,<1,0,0> ANGLE VEC=<1,0,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN3 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<0.5,0,0>,<0,0,1> ACTL/<0.5,0,0>,<0,0,1> TARG/<0.5,0,0>,<0,0,1> ANGLE VEC=<1,0,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS, , , , , , DIM DIST1= 2D DISTANCE FROM PLANE PLN1 TO PLANE PLN2 PAR TO XAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 1.0000 ----#---- DIM PARL1= PARALLELISM OF PLANE PLN1,RFS TO PLANE PLN1,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- DIM PERP1= PERPENDICULARITY OF PLANE PLN1,RFS TO PLANE PLN1,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/ROTATE_OFFSET,120,ABOUT,ZPLUS ALIGNMENT/END PLN4 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<0,0,0>,<0.5,-0.8660254,0> ACTL/<0,0,0>,<0.5,-0.8660254,0> TARG/<0,0,0>,<0.5,-0.8660254,0> ANGLE VEC=<-0.5,0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN5 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<-0.5,0.866,0>,<-0.5,0.8660254,0> ACTL/<-0.5,0.866,0>,<-0.5,0.8660254,0> TARG/<-0.5,0.866,0>,<-0.5,0.8660254,0> ANGLE VEC=<-0.5,0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN6 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<-0.25,0.433,0>,<0,0,1> ACTL/<-0.25,0.433,0>,<0,0,1> TARG/<-0.25,0.433,0>,<0,0,1> ANGLE VEC=<-0.5,0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS, , , , , , DIM DIST2= 2D DISTANCE FROM PLANE PLN4 TO PLANE PLN5 PAR TO XAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 1.0000 ----#---- DIM PARL2= PARALLELISM OF PLANE PLN4,RFS TO PLANE PLN5,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- DIM PERP2= PERPENDICULARITY OF PLANE PLN4,RFS TO PLANE PLN6,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/ROTATE_OFFSET,120,ABOUT,ZPLUS ALIGNMENT/END PLN7 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<0,0,0>,<0.5,0.8660254,0> ACTL/<0,0,0>,<0.5,0.8660254,0> TARG/<0,0,0>,<0.5,0.8660254,0> ANGLE VEC=<-0.5,-0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN8 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<-0.5,-0.866,0>,<-0.5,-0.8660254,0> ACTL/<-0.5,-0.866,0>,<-0.5,-0.8660254,0> TARG/<-0.5,-0.866,0>,<-0.5,-0.8660254,0> ANGLE VEC=<-0.5,-0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO PLN9 =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,NONE,LEAST_SQR THEO/<-0.25,-0.433,0>,<0,0,1> ACTL/<-0.25,-0.433,0>,<0,0,1> TARG/<-0.25,-0.433,0>,<0,0,1> ANGLE VEC=<-0.5,-0.8660254,0>,RADIAL SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS, , , , , , DIM DIST3= 2D DISTANCE FROM PLANE PLN7 TO PLANE PLN8 PAR TO XAXIS,NO_RADIUS UNITS=IN,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 1.0000 ----#---- DIM PARL3= PARALLELISM OF PLANE PLN7,RFS TO PLANE PLN8,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- DIM PERP3= PERPENDICULARITY OF PLANE PLN7,RFS TO PLANE PLN9,RFS UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX MEAS M 0.0000 #-------- ASSIGN/VAR_LIST_DIST=ARRAY(DIST1.M.MEAS,DIST2.M.MEAS,DIST 3.M.MEAS) ASSIGN/VAR_DIST_MAX=MAX(VAR_LIST_DIST) ASSIGN/VAR_DIST_MIN=MIN(VAR_LIST_DIST) CIR_WIDTH_MAX=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,MAX(VAR_LIST_DIST) CIR_WIDTH_MIN=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,VAR_DIST_MIN FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, , DIM LOC1= LOCATION OF CIRCLE CIR_WIDTH_MAX UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 1.0000 1.0000 0.0020 0.0020 0.0000 0.0000 ----#---- END OF DIMENSION LOC1 DIM LOC2= LOCATION OF CIRCLE CIR_WIDTH_MIN UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 1.0000 1.0000 0.0020 0.0020 0.0000 0.0000 ----#---- END OF DIMENSION LOC2 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS, , , , , , ASSIGN/VAR_LIST_PAR=ARRAY(PARL1.M.MEAS,PARL2.M.MEAS,PARL3 .M.MEAS) ASSIGN/VAR_PAR_MAX=MAX(VAR_LIST_PAR) ASSIGN/VAR_PAR_MIN=MIN(VAR_LIST_PAR) CIR_PAR_MAX=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,VAR_PAR_MAX CIR_PAR_MIN=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,VAR_PAR_MIN FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, , DIM LOC3= LOCATION OF CIRCLE CIR_PAR_MAX UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 0.0000 0.0000 0.0020 0.0000 0.0000 0.0000 #-------- END OF DIMENSION LOC3 DIM LOC4= LOCATION OF CIRCLE CIR_PAR_MIN UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 0.0000 0.0000 0.0020 0.0000 0.0000 0.0000 #-------- END OF DIMENSION LOC4 FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS, , , , , , ASSIGN/VAR_LIST_PERP=ARRAY(PERP1.M.MEAS,PERP2.M.MEAS,PERP 3.M.MEAS) ASSIGN/VAR_PERP_MAX=MAX(VAR_LIST_PERP) ASSIGN/VAR_PERP_MIN=MIN(VAR_LIST_PERP) CIR_PERP_MAX=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,VAR_PERP_MAX CIR_PERP_MIN=GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,0>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>,$ DIAMETER/0,VAR_PERP_MIN FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;MEAS,NOM,TOL,DEV,OUTTOL, , DIM LOC5= LOCATION OF CIRCLE CIR_PERP_MAX UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 0.0000 0.0000 0.0020 0.0000 0.0000 0.0000 #-------- END OF DIMENSION LOC5 DIM LOC6= LOCATION OF CIRCLE CIR_PERP_MIN UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX MEAS NOMINAL +TOL -TOL DEV OUTTOL D 0.0000 0.0000 0.0020 0.0000 0.0000 0.0000 #-------- END OF DIMENSION LOC6
You can automatically create arrays like this :
Code:V1 =LOOP/START,ID=YES,NUMBER=30,START=1,SKIP=, OFFSET:XAXIS=0,YAXIS=3,ZAXIS=0,ANGLE=0 ASSIGN/DIST_ARRAY[V1]="DIST"+V1+".MEAS" LOOP/END ASSIGN/DIST_MAX=MAX(DIST_ARRAY)
by hertangelHello,
how do you report MIN or MAX id that's what the drawing asking.
in other words the print calls for 25 max dimater.-
12-20-2011, 12:24 PM -
by cfranklinGood morning all :
When u print out a report, the max and min are supposed to display what values??? Is it the max and min due to the...-
01-30-2009, 10:35 AM -
by ADAM WALLACEWhen I measure a circle and dimension max/min it gives me the max/min but once I close the program and reopen it the max/min show a 0.0000 value. Has...
01-04-2013, 11:55 AM -
by MikeFI ran a part with the min/max turned off, the customer wants the diameter min/max so I go back in the program turn on min/max output and they show min...
10-24-2018, 10:52 AM -
by TKOFaithMy print calls for the surfaces of four bosses be co-planar within .010 TIR. So I would like to have PC-DMIS calculate the Min and Max and output a report...
02-05-2019, 02:47 PM -
