Diameter size
  • Diameter size
    I have a callout with a diameter size with zero tolerance and the location of the diameter with a +/- .005" tolerance, How do I find where the diameter is located within the tolerance band?
    If there aren't any modifiers in the TP FCF that call out is bunk. You most likely have a material modifier on one or more of your datums in the FCF. If this is the case you'll have to use Xact measure.
    Edit: my bad I thought this was a position question. Sorry about that.
    • sallen
      sallen commented
      I added a pic of the callout, back in my quindos day we used to use a custom command to find the basic diameter size then have it report the z location out, I can't seem to figure that out with PC Dmis
    • A_Shomshor
      A_Shomshor commented
      If this an ISO thing, I'm not your guy. This is a bogus call out in ASME. Check the notes on your print. Sorry, that's all I got. Good luck.
    You will need to create a cone on the surface. Then you can construct a circle of the required diameter from the cone. Click Insert> Feature> Constructed> Circle. Select your cone from the list. From the dropdown, select Cone, From the next dropdown, select diameter and key in .244. Hit create. This will create a circle of diameter .244 on the cone. You should be able to dimension the depth of the circle from this. Then repeat the process for the other circle. HTH
      I guess that's just another way to say that they are basic diameters. Do like Mike says and you should be all set.
      PC-DMIS 2016.0 SP8
      Jeff
        Is it a cone all the way through? What's the 0.333 distance on the left and the 0.143 above the diameters represent? Are the two dashed lines representing a straight wall? At what depth is the Ø0.244 and Ø0.249 being measured to obtain a "basic" diameter? There seems to be missing information on this print.
          the .333 is a step and those look like 2 step diameters not a cone at all, .333 is the location of the step between 2 diameters of .244 and .249 is my interpretation
          • bfire85
            bfire85 commented
            I concur with you.
          • Douglas
            Douglas commented
            .143 dimension needs clarification to me still though, it could define the zone for a different tolerance or finish on the same nominal diameter, seen that sort of thing before but from this view alone I see nothing
          also... if I am correct good luck checking that .333 step location
          • UKCMM
            UKCMM commented
            They cannot be step features as they are not shown as solid lines in the section view, they are most likely gauge position ref the two gauge diameters on the cone surface.
          • Douglas
            Douglas commented
            well, +0/-0 is a convention thrown out the window so I would not count on that
          I would set the part up and measure it with our bullshitometer. Never failed me yet.
