I need to setup a diameter of 1.360" tangent to 2 lines... i have tried and tried to figure it out by myself and keep failing ....
Anybody got the scoop on this please help
If it is, you might need to construct reverse lines from your lines to flip the direction of them. There are 4 possible locations for the circle to end up, so if PC-DMIS is putting it in the wrong location, you may need to reverse 1 or both of the lines to get it to construct in the correct location
Sooo, I have started to use this quite often. But I have to mess with it to get it to work correctly, I just make changes until.... it works.... MAGIC...
When using GRAPH=ON when dimensioning is there a way to remove the lines and just have the arrow deviation. I've been serching but haven't found the answer...
