Solved!!
I don't use the quick feature option that much. But I have found that the first hit in each of the auto features is slightly deeper that the rest (approximately .00015). Just slightly annoying to go into each feature and adjust the depth. Has anyone else seen this? 2019R2
EDIT: Also the first hit is not vectored correctly.
Had VOID DETECTION TURNED ON.
CIR_16 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<102.43,-0.684005,[COLOR=#c0392b]0[/COLOR]>,<0,0,1>,0.098 ACTL/<102.43,-0.684005,0>,<0,0,1>,0.098 TARG/<102.43,-0.684005,0>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=4, [COLOR=#c0392b]DEPTH=0.03[/COLOR],PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=3,SPACER=0.08 AVOIDANCE MOVE=BOTH,DISTANCE=0.75 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=YES HIT/BASIC,<102.470469,-0.656377,[COLOR=#c0392b]-0.030153[/COLOR]>,<-0.8258976,-0.5638202,0>,<102.470469,-0.656377,-0.030153> HIT/BASIC,<102.43,-0.635005,-0.03>,<0,-1,0>,<102.43,-0.635005,-0.03> HIT/BASIC,<102.381,-0.684005,-0.03>,<1,0,0>,<102.381,-0.684005,-0.03> HIT/BASIC,<102.43,-0.733005,-0.03>,<0,1,0>,<102.43,-0.733005,-0.03> ENDMEAS/ CIR_17 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<99.59,-0.684005,[COLOR=#c0392b]0[/COLOR]>,<0,0,1>,0.098 ACTL/<99.59,-0.684005,0>,<0,0,1>,0.098 TARG/<99.59,-0.684005,0>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=4,[COLOR=#c0392b]DEPTH=0.03[/COLOR],PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=3,SPACER=0.08 AVOIDANCE MOVE=BOTH,DISTANCE=0.75 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=YES HIT/BASIC,<99.630469,-0.656377,[COLOR=#c0392b]-0.030139[/COLOR]>,<-0.8258976,-0.5638202,0>,<99.630469,-0.656377,-0.030139> HIT/BASIC,<99.59,-0.635005,-0.03>,<0,-1,0>,<99.59,-0.635005,-0.03> HIT/BASIC,<99.541,-0.684005,-0.03>,<1,0,0>,<99.541,-0.684005,-0.03> HIT/BASIC,<99.59,-0.733005,-0.03>,<0,1,0>,<99.59,-0.733005,-0.03> ENDMEAS/
