If there is no basic dimension to control location of a profile then it's just FORMONLY, correct.
formandlocation
Originally posted by John Kingston View PostAre you asking us, or telling us?
You are partially correct, but I couldn't resist.!LOL!
What does the symbol look like? An arc with no bottom, or with a line?When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by John Kingston View PostSorry, couldn't resist. With the line means form & location, but if there is no basic there is an error on the drawing.
ARC without the line is PROFILE OF A LINE (2-D)
Examples of this would be (sheet metal)
PROFILE OF A SURFACE for all the surface and profile of a line for the edge of the surface.
FORM and LOCAITON will come into play by way of the datums called out. No datums in the FCF (profile 1.0mm) is form only. IF even 1 datum is in the FCF, then it is form and location since it has to be held in relationship to said datum.
As for a basic dimension, there is no basic dimension for profile. There has to be a tolerance value, but no basic.
Geez, John, I would have thought you would have gotten that one!sigpic
Originally posted by Matthew D. Hoedeman View PostARC with a bottom line, is PROFILE OF A SURFACE (3-D)
Originally posted by Tested View PostSo this is not a good callout? ATTACH]1315[/ATTACH][sigpic
Originally posted by Matthew D. Hoedeman View PostI would say not, simply because the toleranced surface will NOT have any deviaiton to the A datum, it is perpendicular to the A datum. Maybe they wanted a perp. callout? I mean, check a point on that surface, is there any deviation in the axis that is the A datum? NOPE!
My GD&T book seem to suggest that if there are no Basics holding it's location then it is form only.
But if there are bacics holding it; it does say that now it's form and location.
I would agree that what they want is to control the surface perp. to datum A. Why they called it out that way I don't know. I don't think it is an invalid callout. Although, it would be much more clear if they had put a basic 90º in there. Kev, you want to weigh in on this one?
I knew that! No clue what I was thinking.... I humbly apologize for my poor answer. I will not drink one beer this weekend as penance.When in doubt, post code. A second set of eyes might see something you missed.
by JHamm21I have this feature control frame with 3 parts to it. I know I should know this, but have never had to use it before. How do you dimension all 3 fcf's...
09-15-2016, 02:15 PM -
by TCeckelsWhy does this always seem to happen on Fridays?
I've got a print (suspect part attached) with a "18° typ" call out on it. I've...-
02-08-2008, 02:00 PM -
by Chinadaddy02
Good morning and happy holidays
Been running on ver. 3.5 for a while, now working at a place that is using 4.3 Rel for...-
12-21-2010, 09:12 AM -
by SAguyHi everyone,
I'm new to the forums and DMIS in general. So far I seem to have everything down good except for this one nagging issue:...-
Channel: PC-DMIS Portable
03-31-2011, 03:13 PM -
by keegoSo how does PC-Dmis calculate profiles? If my profile tolerance is 0.2, do I split it to ±0.1? I'm thinking yes because on some of these for forma...
08-20-2010, 08:50 AM -
