True Position
  • True Position
    All,
    I am trying to measure a 4mm hole on a diameter. This hole has a positional tolerance of .2mm from a diameter. I do not have a CAD model. I have my part fixed between centers. I already have an alignment that I recall using the centers. Can someone walk me through on how to code this. I have been struggling. There is a picture of the hole for reference.
    You have to check the drilled hole as a cylinder. Level on the " main shaft " then rotate to the cylinder.
      Do it in Summary Mode and let it write the code for you.
