Hello All,
I've run into an issue I've never seen before and I don't know if it's something I'm doing within the routine or an issue with the CAD model I'm using. In 2 different locations of my part I have a Boss within a hole. 1 is an O-ring groove, the other is a port. The O-ring groove has draft angle walls so I'm trying to measure the walls as cones but when it travels from 1 hit to the next, the travel path is in the material on the other side of the groove (both ID and OD). The problem with the port is that when it's finished taking hits on the cylinder OD of the boss the probe path goes right back through the boss to come out of the feature.
These collisions are all showing in the path lines / collision detection (I haven't tried them physically). I am using Clearance Cube and I think I may be able to turn it off and add a clearance move to avoid that collision on the port but I don't know what to do about the O-ring groove. I included the info about the port because it seems unusual that the path of an auto feature would travel right through the feature with clearance cube on and thought that might indicate an issue with CAD model. The model was imported as an IGES file.
Thank you in advance for any help you can give.
