Greetings to colleagues
I hope you and your loved ones are in good health
My question is about measuring one part
I thought how to measure the selected size and it occurred to me only two ideas
1. two lines intersect the theoretical circle (created using constructed circle ), the distance between two points, and the middle point between them as the center of the circle. In this case, the measurement is almost completely green, TP is almost green. But I understand that the intersection points are not on the 48th diameter, as required by the drawing.
2. I create a vector point approximetely where I need at 3d model and through the polar coordinates I set R 24 (I do not change the angle), also from the opposite side. Now the distance between them goes far beyond the tolerance and the whole dimension is red. But I know that the point is now on diamter 48.
Maybe someone will tell me a more correct direction for this measurement.
P.S.
I use xact for TP
P.S.
I use xact for TP
