Problem: I have a shaft between centers with a 4mm hole on the diameter that we are measuring. we are trying to measure the center position of this hole. the position is supposed to be 0.00. I am currently clocking the part with the hole pointing up at 12 o'clock. Then, I come over in DCC mode and probe the hole. My origin is set at the cone tip. with Y AXIS running down the center of the part. I have been struggling to get a a measurement for center position. Any tips on how to approach this would be great.
Finding the center position of a hole on a diameter
Art name : Isl cam inspection 5_28_2020
rev number :
Ser number :
Stats count : 1
startup =alignment/start,recall:use_part_setup,list=yes
alignment/end
mode/dcc
movespeed/ 35
touchspeed/ 3
format/text,options, ,headings,symbols, ;nom,tol,meas,dev,outtol, ,
loadprobe/2mm x 21mm probe
tip/t1a0b0, shankijk=0, 0, 1, angle=0
recall/alignment,external,cam fixture alignment_5_27_2020
move/point,normal,<39.740,7.531,163.101>
c-face =feat/plane,cartesian,triangle
theo/<-0.092,22.87,15.979>,<0.0020528,-0.9999979,0.0000945>
actl/<-0.092,22.787,15.978>,<0.00202,-0.9999979,0.0002702>
meas/plane,3
hit/basic,normal,<24.288,22.92,10.393>,<0.0020528,-0.9999979,0.0000945>,<24.288,22.835,10.392>,use theo=yes
move/point,normal,<24.405,20.925,26.406>
move/point,normal,<1.252,20.896,27.432>
hit/basic,normal,<1.25,22.874,27.433>,<0.0020528,-0.9999979,0.0000945>,<1.25,22.793,27.431>,use theo=yes
move/point,normal,<-25.805,20.837,27.437>
hit/basic,normal,<-25.815,22.817,10.11>,<0.0020528,-0.9999979,0.0000945>,<-25.814,22.734,10.11>,use theo=yes
endmeas/
move/point,normal,<-25.806,20.816,41.975>
move/point,normal,<-0.093,-9.645,49.724>
move/point,normal,<-0.095,-9.645,20.456>
4mm hole =feat/cylinder,cartesian,in,least_sqr
theo/<-0.171,-9.659,19.546>,<0.0068711,-0.0006818,-0.9999762>,3.976,1.831
actl/<-0.068,-9.744,19.547>,<0.0031687,0.0003643,-0.9999949>,3.976,1.822
meas/cylinder,8
hit/basic,normal,<1.81,-9.629,20.461>,<-0.9998614,-0.0151674,-0.00686>,<1.908,-9.552,20.458>,use theo=yes
hit/basic,normal,<-0.217,-7.673,20.453>,<0.0199082,-0.9998015,0.0008185>,<-0.313,-7.771,20.451>,use theo=yes
hit/basic,normal,<-2.166,-9.689,20.448>,<0.9998589,0.0153324,0.0068599>,<-2.053,-9.58,20.452>,use theo=yes
hit/basic,normal,<-0.147,-11.645,20.455>,<-0.015652,0.9998772,-0.0007893>,<-0.267,-11.723,20.455>,use theo=yes
move/point,normal,<-0.165,-9.649,18.639>
move/circular
hit/basic,normal,<1.823,-9.635,18.644>,<-0.9998954,-0.0127289,-0.0068619>,<1.913,-9.551,18.643>,use theo=yes
hit/basic,normal,<-0.189,-7.671,18.636>,<0.0117667,-0.9999305,0.0007626>,<-0.279,-7.768,18.636>,use theo=yes
hit/basic,normal,<-2.154,-9.69,18.629>,<0.9998651,0.0149245,0.0068602>,<-2.047,-9.584,18.634>,use theo=yes
hit/basic,normal,<-0.147,-11.649,18.636>,<-0.0092328,0.9999571,-0.0007452>,<-0.262,-11.721,18.636>,use theo=yes
endmeas/
move/point,normal,<-0.149,-9.657,76.378>
move/point,normal,<-513.855,389.155,73.140>
4mm cl =feat/line,cartesian,unbounded,no
theo/<-0.178,-9.659,20.461>,<0.0068711,-0.0006818,-0.9999762>
actl/<-0.071,-9.744,20.458>,<0.0031687,0.0003643,-0.9999949>
constr/line,cast,4mm hole,1.831,dependent
origin =feat/point,cartesian,yes
theo/<0,0,0>,<0,0,1>
actl/<0,0,0>,<0,0,1>
constr/point,origin
xy plane =feat/plane,cartesian,triangle,yes
theo/<0,0,0>,<1,0,0>
constr/plane,align,workplane
y axis =feat/line,cartesian,unbounded,yes
theo/<0,0,0>,<0,-1,0>
constr/line,cast,origin,35,dependent
lin3 =feat/line,cartesian,unbounded,no
theo/<-0.007,-17.499,1>,<0.0068711,-0.0006818,-0.9999762>
actl/<-0.003,0,1.5>,<0.0031687,0.0003643,-0.9999949>
constr/line,plto,4mm hole,y axis,1
dim dist1= 2d distance from cylinder 4mm hole to line lin3 par to xaxis,no_radius units=mm,$
graph=off text=off mult=10.00 output=both
ax nominal +tol -tol meas dev outtol
m 0.000 0.100 0.100 0.067 0.067 0.000 ---#
by pnwenz89All,
I am trying to measure a 4mm hole on a diameter. This hole has a positional tolerance of .2mm from a diameter. I do not have a CAD...-
06-01-2020, 02:10 PM -
by supahonkeyI am new to PC-DMIS. I've been trained with Zeiss Calypso and a lot of stuff is different! I have a few holes in a part that I am trying to get the...
12-23-2010, 09:01 AM -
by JackarrooHello everyone!
I need your help. I feel silly and tired. I have posted a simplified part diagram below, a cylindrical pancake, with a hole through...-
12-19-2018, 05:52 PM -
by CaemgenOk, I have to check a part as shown in the pic.
The start of the hole is at the arrowhead with a position of .014 applied to it.
02-24-2014, 01:51 PM -
by PC DMIS GUYHi guys, I’m still fairly new to programming, I’ve been to the basic class so bare with me. How would I go about finding the position of the angled...
07-30-2020, 04:10 PM -
