I have a Sheffield Discovery 2 with a UMP360 control on it, the computer took a crap and I had to replace it with a windows 10 box. I then had to install 2018 on it from 4.3. Now when I start it up it appears to home out but it doesn't say "done initializing" and there are no readings on the scales. It then kicks the servo motors out and is locked up. Error 175 is a Z axis bias error I am told but I find it hard to believe that it doesn't have to do with the computer or software change. Any ideas?
Error 175
I keep getting a TR_FG116,X Amplitude Error that causes an emergency shutdown error. Most of the time I loose my COM PORT and have to delete the COM PORT...
05-22-2014, 09:38 AM -
by Budking21This error continues to pop up when I change a head position, arrow though or make changes to a program, when I try to save a program, and when I first...
04-01-2009, 02:29 PM -
by SI_GUY_29In the control box the led message is blinking E-1-6-3. I looked up the error and all I found was that, that error means "Y axis bound up"....
12-26-2018, 07:07 AM -
by dbyerlyWhen I do a machine start and click ok, the probe starts moving for the home postion but stops within 2 seconds. I have turned off the CMM, computer etc...
09-28-2009, 11:37 AM -
by Brandnewi tried looking via the search and nothing showed up. i'm not sure if i've seen this before but i'm just curious if someone knew what this meant?...
03-11-2010, 01:04 PM -
