You ever seen a cylinder type of part drawing where calls a hole position with two datums, one datum is A (X direction) from the edge but the other datum B is the actual inside diameter of the cylinder meaning that you can place that hole really anywhere in Y direction around the cylinder since there is no rotation constraints.
In this case can i use the hole diameter deviation as datum B? PLease let me know if you don't understand what im saying so i can draw something. Thanks.
