Gage R&R question
  • Gage R&R question
    When performing a gage R&R for a profile of a surface, if I have 70 points around a surface, do you perform a gge r&r for every point (70 times) or do you get an average or min/max type of calculation and then yo use that to estimate the overall gage r&r of that profile of surface.
    Thanks
    individual points only. If you use the "profile" values, the 'high' point or 'low' point will change. You have to compare apples to apples not apples to apple pie.
      You can also use MIN/MAX but using the individual points pulled from the actual scan that is used would work as well.
      Contura Calypso 5.4
