I am trying to write a CMM report reflecting the information on the customer's drawing. The issue is I cannot get XactMeasure to report the GD&T displaying the datums with dashes between them, as shown in this drawing. Can anybody help please.GDT DATUM QUERY.jpg
Reporting with dashes between datums
Hi gibsonridge.
Thanks for the reply.
There are three datums defined on the drawing. A, B and C.
A is the master plane
B is the centre of the counterbore
C is the centre of the widest slot in Y
My issue is, that when creating my report, how do I call up | A | B-C | B | in PC Dmis as datums for reporting the true pos, form and location. PC Dmis does not give me the option
Thanks in advance.
You can create a compound datum; first create the DRF with the first datum then create; then insert a dash followed by the second datum.
Code:FCFLOC1 =POSITION : CIR_C FEATCTRLFRAME/SHOWNOMS=NO,SHOWPARAMS=NO,SHOWEXPANDED=NO, SIZE TOLERANCES/1,DIAMETER,0.205,0.004,0.003 PRIMARY DIMENSION/POSITION,DIAMETER,0.084,MMC,D,A,[COLOR=#e74c3c]B-E[/COLOR] NOTE/FCFLOC1 FEATURES/CIR_C,,
- Likes 1
Thanks all
Hi sealevel
I have constructed the generic circle where my slot midplane is. Called the generic circle datum C.
When I come to report the true position of the end face (just started there as an example), I can not type in the B-C datum callout in Xact.
I can only use my A and B datums, the go into the program (the edit window) and type over the B datum with B-C, then add a B callout later.
I then get an error as shown in the image
So, now my report reflects the customer drawing, but it reports that the end face is a country mile out. I am programming offline with nominal CAD.
Measuring the end face in position only, I get the correct result
DIM LOC1= LOCATION OF PLANE RGHT_END UNITS=MM ,$
X 275.500 0.001 0.001 275.500 0.000 0.000 ----#----
END OF DIMENSION LOC1
Sorry to be a pain, but any help would be greatly appreciated.
The FCF is redundant. Normally a dashed datum should indicate things that are coaxial where the two datums are non continuous features that may or may not be the same size.
In this case, |A|B|C| accomplishes the same thing the horror your FCF thinks it does - A controls one axis and sets the origin, B alone creates the origin of the other two axis, leaving nothing but the final rotation, controlled by C.
- Likes 2
Exactly. This is a goofy drawing all-around. The longer I look at it, the worse it gets.
Just now reading this. I was looking at the drawing above and was saying to myself, there is NOT 1 callout that says A|B|C, So I'm with RandomJerk here.
A=PLANE, LEVEL and ORIGIN Z
B-C = (CONSTRUCTED) LINE (from B to C) ROTATION ONLY
B=CYLINDER OR CIRCLE, ORIGIN X and Y
by GroverI am trying to report the parallelism of 3 planes. I have 2 of them set up as different datums. When I try to report out the third plane to the 2 datums,...
08-10-2018, 08:21 AM -
by m.gomezCan anyone explain this? Do I use this long with "use datums" what happens if I don't use this feature? It's pretty confusing on my end. Thanks...
03-31-2014, 02:25 PM -
by Jan d.Another one for you brainiacs...
Please review the attachment. Sorry for the funky colors. On the right there is a flat plane defined,...-
09-11-2006, 03:03 PM -
by pab39Hi guys,
I'm not a GD&T expert, and i am asked to measure that perpendicularity:
What does that mean exactly ? i...-
02-05-2018, 02:48 PM -
by Moore RacingI'm running 2015-1 and recently installed updates.. It changed the way I normally report position.. It seems very cumbersome and I had no problem
01-08-2018, 11:17 AM -
