Hi.
I've been reading in ISO 5459:2011 about datums and datum systems. It's very informative but somehow leaves me with more questions than I had before reading it...
I'll just post one of those for now.
So the standard explains establishing a datum system from a cylinder and a perpendicular plane, where the cylinder is the primary datum (A), perpendicular to the plane (secondary datum B).
Next,
the standard explains establishing a common datum from a plane and a perpendicular cylinder, where the plane is the primary datum (A), perpendicular to the cylinder (B). Only in this example it's a common datum (A-B).
Why? Why does one use common datums in some cases? What would the difference be if the second example was also a datum system?
As far as I can see the end result is a straight line and a point in both examples. So what is the difference?
Anyone?
Next,
Anyone?
