I'm using PC-DMIS version 4.1, the problem I'm having is, when I try to get a -Z- axis dimension from a hole to hole, or anything it will not give me the option, my only options are, to feature, -X-, or -Y-. I have other programs written that it does give me this option. Need some help on this one..
Can't get -Z- axis to report
Originally posted by JamesMannes View PostI am assuming a distance dimension is being asked for. Distance dimensions are workplane specific, for a "Z" type of distance dimension you will need to in the "X' or "Y" workplane in order for PC-DMIS to "see" the distance properly.sigpic
Originally posted by Goodluck View PostI actually didn't see the study. Are they absolutely shure it's the alcohol causing the shrinkage. I mean had the study's subjects been in the pool?sigpic
by chefhmoralesWhen using the Distance Dimension the Y Axis is blocked (grayed out) unable to select.
Why and how could I make this axis active?-
09-30-2010, 10:26 AM -
by Marc in SWI have a part with a lot of steps(200+). I have measured the tight tolerance ones by using vector points. There are alot of steps and the areas to be...
02-05-2008, 10:13 AM -
by bradburrowsHello,
I'm quite new to the CMM universe and I have a measuring task where I'm unsure if I evaluate it correctly.
The task is...-
10-17-2019, 10:37 AM -
by Jason_SI would like top preface this post by saying I have been looking for a solution to this problem but haven't found anything relevant. If this is repetitive...
07-09-2019, 02:42 PM -
by Jared SI am in the middle of finishing someone elses program and during the dimensioning, I've come across an Axis problem. The "Y" axis is not a...
Channel: PC-DMIS Portable
01-19-2015, 07:57 AM -
