2020 r1 sp3
  • 2020 r1 sp3
    here :
    https://www.wilcoxassoc.com/public/P...20_R1/SP3/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP3/x64/
    Release Notes - 2020 R1
    SP3
    • PCD-47924 - Fixed an issue where PC-DMIS didn't execute the Go 6DoF
    command when you pressed Alt + F9 for the AT960 and AT901 trackers.
    • PCD-123716 - Fixed an issue where the IMAGECAPTURE command added a
    blank feature label when you had generated the report.
    • PCD-155565 - Fixed an issue where Laser scanning performance was
    affected with blue and purple points when you re-executed a measurement
    routine.
    • PCD-164073 - Fixed an issue where the offline Help didn't work even when
    the offline help was installed and the Use Offline Help option was selected.
    • PCD-171401 - Fixed an issue where a laser pointer was not activated when
    you had done the machine configuration.
    • PCD-177404 - Fixed an issue where the Probe Toolbox dialog box appeared
    when the Feature Extraction tab was active and you clicked Cancel in the
    Laser Auto Feature dialog box.
    • PCD-183366 - Fixed an issue where PC-DMIS didn't change the file type for
    the COP ID in the Edit window when you changed the file type from the Type
    list in the Pointcloud Operator dialog box.
    • PCD-185964 - Fixed an issue where some scan data were not imported
    properly when you used the Simulate Pointcloud function.
    • PCD-186792 - Fixed an issue where a distortion calibration file was not
    created when a vision probe with multiple tips was calibrated for Pixel Size
    and Distortion.
    • PCD-186848 - Fixed an issue where pre-defined Pointcloud Display | Mesh
    display profiles were visible in the Laser Data Collection Settings dialog
    box for DCC CMMs.
    • PCD-186957 - Fixed an issue where PC-DMIS didn't generate a unique probe
    name for each orientation when you worked on UCCServer.
    • PCD-187251 - Fixed an issue where a measurement routine was not created
    or opened when you used a portable SCANMESH license with the AICON -
    Offline interface.
    • PCD-187589 - Fixed a software crash that occurred when you imported a
    pointcloud file that didn't have stripe information and created the Grid mesh.
    • PCD-187655 - Fixed an issue where PC-DMIS didn't display the Pointcloud
    select area when you edited the Select command from the Pointcloud
    • PCD-188327 - Fixed an issue where PC-DMIS reported incorrect values of
    D1, D2, and D3 when you had generated the statistics.xml file.
    • PCD-188784 - Fixed an issue with the I++ interface where automatic tool
    changes took place when you moved your cursor position in the measurement
    routine.
    • PCD-189225 - Fixed an issue where PC-DMIS didn't create multiple Mesh
    Thickness colormaps when you executed a measurement routine.
    • PCD-190223 - Fixed an issue where the Pointcloud or Mesh shading was lost
    and became flat when the COP or Mesh was picked from the Pointcloud
    Operator or Mesh Operator dialog box.
    • PCD-191253 - Fixed an issue where PC-DMIS failed to extract BH Laser
    features when the pointcloud was far away from the CAD model.
    • PCD-191781 - Fixed a software crash that occurred when you opened your
    measurement routine in modes other than the Operator Mode.
    • PCD-192474 - Fixed an issue where the laser auto features were not
    automatically executed when data was received from a TCP/IP transfer, such
    as the AICON OptoCat software.
    Hi JEFMAN
    Do you know where to find more information about this fix PCD-186957
    • JEFMAN
      JEFMAN commented
      No, sorry, maybe in the help file ?
    The user has to setup logical name for each orientation on the UCCServer side and nickname for each tip (A,B angle combination) on the PC-DMIS side. It is very laborious.
    The idea is that we allow to specify RenishawServer Option bit 5 (32) ToolNameTranslation. When it is set the nickname for T1A0B0 will be used as probe name (alternate dot character - AltDotChar option - can be used for dots in name - for instance TP2020x2#1#20#2 will be translated to TP2020x2.1.20.2 And each angle will be generated by UCC server rules. for instance with previous example for the probe name and angles A 45 and B 90 PC-DMIS will generate TP2020x2.1.20.2.A45.0-B90.0.
    • Klaus Omer
      Klaus Omer commented
      Hi Radim thanks for your reply :-)
    I'm back to the cmm .
    Installed SP3 today, tested...
    First, cmm didn't recognize LSPX1H (prbdata not available) and it was impossible to activate it under testsoft (prb nul).
    Then, I ran 2019 R2 to check if it was a problem on the controller or on the version, 2019 R2 works fine.
    I re-ran 2020, then LSPX1 was recognized, but unable to take a hit (no detection of the calibration sphere : wrist default).
    Under test soft, it was possible to toggle(not sure of the word : driving the cmm motors just by touching the stylus !).
    I also tried optical calibration distorsion, nothing changes, it crash pc-dmis and go to windows...
    Don Ruggieri , NeilRyan
    • JEFMAN
      JEFMAN commented
      Don Ruggieri : ok, I will send it tomorrow...
    • vpt.se
      vpt.se commented
      Thanks for your feedback, JEF!
    • NeilRyan
      NeilRyan commented
      We are aware tof the previously reported crash with the CMMV and your controller. We had planned to investigate this but due to the current lockdowns we have been unable to access the required hardware for debugging and testing. As soon as the situation changes, I will schedule that issue include for consideration in the Service Pack.
      Regarding the LSPX1 not being recognised I am unsure to the cause. Again, without access to hardware it is difficut for us to investigate. Hopefully Don Ruggieri can access his hardware to test further
    +1 ....works as advertised!!
    . This was a long time issue for me unless working around the prob by manually hunting down and installing the OFFline help.
    A baby step in the positive direction!
