lost my model
  • lost my model
    how can i bring my model back into my program?
    put it back where it was before you moved the PRG file.
      If it's just a case of moving files, you could also re-import the model, right?
        I trashed it by accident. when I restored it, no model.
          You can check to see if there is a <prog number>.CAD then re-import it.
            Go into EDIT>Graphics Display Window>CAD Assembly and look if there is still anything showing in the list of CAD entities (bottom left of dialogue). If there is, they should have a checkbox next to them that turns the visibility on and off. If you select an item from the list and then look in the upper left area of the dialogue, you should also be able to see information on the model name, file path it was imported from and any transformation that was performed. This would allow you to re-import the model if the current one has become corrupt in some way.
            Neil Challinor
            PC-DMIS Product Owner
            E: [email protected]
              Check the name of .prg & .cad files, there shouldn't be any difference in file names
              other thing you can do is dry run the program and import new model afterwards you can transform the model as per program
