chamfer angles reading off
  • chamfer angles reading off
    Have multiple 45d chamfers with .050" face and a +/- .5 degree tolerance. The probing of the chamfer line is fine; the vectors are consistent--not hitting on the transition, and the form is good.
    Yet some of the chamfers show at say 45.75 degrees while the mold shows more like 45.5 degrees. Consistently reads approx. .25 degrees high. I've tried using 1/2 cone angle, line to cylinder, line to top plane and get the same just out-of-tolerance results. Any alternate probing strategies I'm missing?
    Thank you.
    Paul Schuyler
    You can try this :
    https://www.pcdmisforum.com/forum/pc...-with-2-points
      What's the form deviation of the cone?
        You're saying the mold checks 45.5 but the parts coming out of the mold check 45.75? There is always movement of molded parts. If the part continually show 0.25 degrees more than the mold shows, then you need to change the mold to 0.25 degrees under nominal angle.
          the form deviation of the cone is withing a couple of tenths. I'd simply believe the angle was out of tolerance, but the mold tells me otherwise.
            Paul Schuyler
            I'd look at the following:
            1) Is the machine calibrated? (no)
            2) Is the machine using a probe that would yield a high amount of STDDEV (4" long probe at funky compound angles, yes.)
            3) Are you probing a very small (amount of surface area without doing any alignment localization to get yourself closer to the geometry you're trying to measure?? (I believe yes)
            • Axel45
              Whats up with this cone?
              by Axel45
              I am measuring a simple chamfer in z+ as a cone and want the angle of the cone. Every time I dimension it come up 90 deg. I know this cant be true....
              11-15-2006, 06:55 AM
            • PCFreddie
              Angle for tube fitting
              by PCFreddie
              I have a tube that should have a 2 degree angle taper all around I need to check. I measured the tube as a cone and constructed a cast line through it...
              01-05-2011, 05:57 PM
            • J. Lusk
              cone angle
              by J. Lusk
              How would you measure the angle of the face of a cone in relation to an adjacent plane? I'm getting a close but no cigar (48 deg. -vs- 50 deg.) When I...
              08-19-2008, 04:13 PM
            • Mike_B
              A weird issue with cone angle.
              by Mike_B
              Im measuring a hydraulic fitting, with a standard JIC 37 degree flare. This angle is what I want to verify.
              I have the fitting facing straight...
              08-22-2014, 12:59 PM
            • JLHUTT
              Checking angles on a cone
              by JLHUTT
              I am new to the programing, first week, so this question my sound pretty basic. When I am checking an angle on a cone, I measure the cone feature and...
              10-12-2007, 07:14 AM
