auto save report
  • auto save report
    how to simplify it so it is more simple
    TRACEFIELD/DISPLAY,LIMIT=15 ; BATCH NUMBER :
    TRACEFIELD/DISPLAY,LIMIT=25 ; REPORT NUMBER : CMM2-J-19
    TRACEFIELD/DISPLAY,LIMIT=25 ; OP NUMBER :
    ASSIGN/REPOR=GETCOMMAND("TRACE FIELD", "UP", 2)
    ASSIGN/REPORT=GETTEXT ("TRACE_VALUE", 1, REPOR)
    ASSIGN/MC=LEFT(REPORT,4)
    ASSIGN/MC_=RIGHT(MC,1)
    ASSIGN/MONTH=SYSTEMDATE("MMMM")
    SELECT/MC_
    CASE/1
    ASSIGN/DATA="\\\IBD1BQA015\CMM_DATA\CMM REPORT TRANSFER" +"\
    END_CASE/
    CASE/2
    ASSIGN/DATA="\\\IDIBDDT806PW5G\CMM_DATA\TEMPORARY REPORT TRANSFER" +"\
    END_CASE/
    CASE/3
    ASSIGN/DATA="E:\PCDMIS FOLDER\REPORT\2020\MAY" +"\
    END_CASE/
    END_SELECT/
    ASSIGN/VR1=DATA+REPORT +"
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,APPEND=VR1,AUTO OPEN REPORT=OFF,$
    TO_PRINTER=OFF,COPIES=1,$
    TO_EXCEL_OUTPUT=OFF,
    Hi,
    Probably you will not simplify code by itself. If you will use TRACEFIELD in CMM program and all rest will move to BASIC SCRIPT then CMM program will have one command as link to script and script will be safe from accidental modifications plus in future if you need change something, changes will apply to all programs which contain link to script.
      The script already export to basic script and make a shotcut for making a new program, then just one click for insert to program
