XactMeasure replacement - 2020R2
Originally posted by dph51 View PostI am so glad I retired.
The onslaught of a zillion questions will soon arrive.
Best of luck to all.Whatever a man sows, he shall reap.
Is possibility to edit nominals value in FCF turn off in 2020R2?
Sometimes blueprint has little different compering to the model and it will be nice to have this back...
If I understand now your recommendation is to sitting with calculator and checking every coordinate if is ok or not? Is this programming speed up?
When I programming I just choosing features on the model, create alignments, move points etc. On this stage everything going almost automatically like it should.Then when I calling dimensions and observe that something need fine tuning I can easy change.
For me is no problem, to have nominal from model for example 21.998 when drawing has 22.000 but many customer have. Now you taken this possibility. Don't be surprise, that many programmers using old fashion legacy method...
darius I am not suggesting the use of a calculator at all. Program using your CAD model while you have a blueprint handy. After each feature creation, check to make sure that your theoretical values are correct. If they are not, then fix them at the time of feature creation.
It would be a shame if customers are using legacy dimensions just because they don't want to make sure that their theoretical values are correct. That is just part of being a thorough programmer.Last edited by JacobCheverie; 09-24-2020, 08:08 AM.
Good luck getting Engineering to make immediate changes!!! We need flexibility as inspectors to get our job done and then make comments on the needed changes. Still sometimes will not happen by the time your measuring the same item again.....sigpicTAU ALPHA PI INDIANA DELTA CHAPTER
by m.gomezThis is just me testing the climate of CMM users preferences:
I have been using PC DMIS for close to 3 years and have been taught from...-
02-25-2014, 08:18 AM -
by MikeFwhy are my position measurements different using xact and legacy?
04-02-2018, 02:52 PM -
by XANTHOFILEI'm relatively new to using XactMeasure as so many of our programs and most of my On-The-Job training are with Legacy dimensioning. So - How do I get...
07-17-2014, 10:16 AM -
by Jrgunn5150At least, I think it is. I've never used it, not familiar at all with it. I used to use CMM Manager in a prior job though, and in that software, you basically...
01-27-2016, 11:56 PM -
by DJAMSAnd if you have the time, please explain why?
We use legacy position for these reasons:- Datum features of size are reported over and over
Legacy87.80%36XactMeasure GD&T12.20%5-
07-25-2009, 12:31 PM
