2019 r2 sp6
  • 2019 r2 sp6
    Here :
    https://www.wilcoxassoc.com/public/P...19_R2/SP6/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP6/x64/
    Release Notes - 2019 R2 SP6
    • PCD-47924 - Fixed an issue where PC-DMIS didn't execute the Go 6DoF
    command when you pressed Alt + F9 for the AT960 and AT901 trackers.
    • PCD-148254 - Fixed an issue where Pointcloud Cross Sections were not
    visible in the Report window when you activated the Snapshot command.
    • PCD-155565 - Fixed an issue where Laser scanning performance was
    affected with blue and purple points when you re-executed a measurement
    routine.
    • PCD-160256 - Fixed an issue where PC-DMIS didn't display the current
    alignment in the Report window when you created the SNAPSHOT command.
    • PCD-171477 - Fixed a software crash that occurred when you had cut a quick
    align group of manual and DCC alignment to paste the group elsewhere.
    • PCD-171891 - Fixed a software crash that occurred in Summary Mode
    (Preview) when you executed a measurement routine with the Thickness
    command.
    • PCD-173164 - Fixed a software crash that occurred in Summary Mode
    (Preview) when you changed the Animation speed percentage from the
    Setup Options dialog box.
    • PCD-180502 - Fixed an issue where you were not able to select the text
    labels when you selected the Back face culling check box on the Lighting
    tab of the CAD and Graphic Setup dialog box.
    • PCD-183366 - Fixed an issue where PC-DMIS didn't change the file type for
    the COP ID in the Edit window when you changed the file type from the Type
    list in the Pointcloud Operator dialog box.
    • PCD-183493 - Fixed a software crash that occurred when you closed the
    measurement routine after the execution of a Laser calibration program.
    • PCD-186461 - Fixed an issue where the CSV converter displayed an error
    message when you imported an EG (square slot) Laser feature.
    • PCD-186675 - Fixed an issue where the left-click on the GD&T callout doesn't
    create any features when you enabled the GD&T Selection Mode and
    Characteristic IDs.
    • PCD-186844 - Fixed an issue where PC-DMIS was not able to rotate the
    probe to an appropriate angle when you were about to perform calibration.
    • PCD-187251 - Fixed an issue where a measurement routine was not created
    or opened when you used a portable SCANMESH license with the Aicon -
    Offline interface.
    • PCD-187655 - Fixed an issue where PC-DMIS didn't display the Pointcloud
    select area when you edited the Select command from the Pointcloud
    • PCD-187973 - Fixed an issue where you were not able to close the Load
    Probe message when you pressed the RomerRDS RA8 arm button.
    • PCD-188006 - Fixed an issue where extra surface anomalies were visible for
    some probe models.
    • PCD-188327 - Fixed an issue where PC-DMIS reported incorrect values of
    D1, D2, and D3 when you had generated the statistics.xml file.
    • PCD-189525 - Fixed an issue where PC-DMIS failed to move the CAD
    objects to a part when you clicked the Move To Part button in the CAD
    Assembly dialog box.
    • PCD-189577 - Added the ability to add the "RANGE_" prefix to the range of
    the Size dimension in Q-DAS Configurator so that the ID is not blank.
    • PCD-189889 - Fixed an issue where the Control string and unit fields were
    missed when Q-DAS Configurator generated the statistics.xml file for the
    UAME axis of the Size ASME command.
    • PCD-191781 - Fixed a software crash that occurred when you opened your
    measurement routine in modes other than the Operator Mode.
