I am checking a part with a 1.5 tip and everything checks fine. when I change to another tip like a 1.0, it raises the scan lines up off the model and reports it way out. How can I fix this?
scan lines are up off the model
still having trouble with the scan not on the part. tried running offline and that didn't help. here is the code.
ALIGNMENT/END
MODE/MANUAL
MANRETRACT/0
TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Zerodur; Nexcera,CTE=0
,SET WARNING LIMIT = TRUE,MINIMUM = 18,MAXIMUM = 22
,PART SENSOR NUM=DEFAULT,X SCALE= 20,Y SCALE= 20,Z SCALE= 20,PART TEMP=20.8013
LOADPROBE/1_5X30
MOVESPEED/ 60
PREHIT/0.04
RETRACT/0.04
SCANSPEED/3
C1 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=YES,TIME DELAY=20,
GO TO DCC ALIGNMENT?
IF_GOTO/C1.INPUT=="YES",GOTO = L1
PNT1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1659,-0.6626,-0.1713>,<0,-0.0487885,0.9988091>
ACTL/<-1.3688,0.796,-16.6004>,<0.0819679,0.0180492,0.9964715>
TARG/<-0.1659,-0.6626,-0.1713>,<0,-0.0487885,0.9988091>
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=YES
AVOIDANCE MOVE=BOTH,DISTANCE=0.04
SHOW HITS=NO
PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1364,-1.018,-0.1887>,<0,-0.0487885,0.9988091>
ACTL/<-1.3688,0.4511,-16.5669>,<0.0843805,0.0553702,0.994894>
TARG/<-0.1364,-1.018,-0.1887>,<0,-0.0487885,0.9988091>
SHOW HITS=NO
PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0.1511,-1.0254,-0.189>,<0,-0.0487885,0.9988091>
ACTL/<-1.1114,0.4506,-16.5649>,<0.1120927,-0.0256266,0.9933673>
TARG/<0.1511,-1.0254,-0.189>,<0,-0.0487885,0.9988091>
SHOW HITS=NO
PNT4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0.1491,-0.6439,-0.1704>,<0,-0.0487885,0.9988091>
ACTL/<-1.1115,0.8437,-16.6034>,<0.1004114,-0.0178705,0.9947855>
TARG/<0.1491,-0.6439,-0.1704>,<0,-0.0487885,0.9988091>
SHOW HITS=NO
PNT5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0.2175,-0.368,-0.1866>,<1,0,0>
ACTL/<-1.0298,1.1046,-16.6593>,<0.9987277,-0.0084039,-0.0497226>
TARG/<0.2175,-0.368,-0.1866>,<1,0,0>
SHOW HITS=NO
PNT6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<0.2175,0.0029,-0.1866>,<1,0,0>
ACTL/<-1.0329,1.4137,-16.6593>,<0.9986182,-0.0086834,-0.0518286>
TARG/<0.2175,0.0029,-0.186>,<1,0,0>
SHOW HITS=NO
PNT7 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.0015,0.098,0.0363>,<0,1,0>
ACTL/<-1.2543,1.5909,-16.4677>,<-0.0108699,0.9873074,0.1584486>
TARG/<-0.0015,0.098,0.0363>,<0,1,0>
SHOW HITS=NO
PLN1 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
THEO/<-0.0005,-0.8375,-0.1798>,<0,-0.0487885,0.9988091>
ACTL/<-1.2401,0.6354,-16.5839>,<-0.0070121,0.0970869,0.9952512>
CONSTR/PLANE,BF,PNT1,PNT2,PNT3,PNT4,,
OUTLIER_REMOVAL/OFF,3
FILTER/OFF,WAVELENGTH=0
LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
THEO/<0.2175,-0.368,-0.1866>,<0,1,0.0000835>
ACTL/<-1.0298,1.1046,-16.6593>,<-0.0099694,0.9999503,-0.0000569>
CONSTR/LINE,BF,3D,PNT5,PNT6,,
A1 MAN =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/TRANS,ZAXIS,PLN1
ALIGNMENT/ROTATE,YPLUS,TO,LIN1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,LIN1
ALIGNMENT/TRANS,YAXIS,PNT7
ALIGNMENT/END
MODE/DCC
L1 =LABEL/
MOVE/POINT,NORMAL,<-0.5648,1.4491,1.9919>
MOVE/POINT,NORMAL,<-0.323,-1.0155,0.88>
PNT8 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3569,-0.7594,0>,<0,0,1>
ACTL/<-0.3569,-0.7593,0.0026>,<0,0,1>
TARG/<-0.3569,-0.7594,0>,<0,0,1>
SNAP=NO
SHOW HITS=NO
PNT9 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3812,-1.1122,0>,<0,0,1>
ACTL/<-0.3812,-1.1124,0.0025>,<0,0,1>
TARG/<-0.3812,-1.1122,0>,<0,0,1>
SNAP=NO
SHOW HITS=NO
PNT10 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.0807,-1.1498,0>,<0,0,1>
ACTL/<-0.0807,-1.1498,0.0025>,<0,0,1>
TARG/<-0.0807,-1.1498,0>,<0,0,1>
SNAP=NO
SHOW HITS=NO
PNT11 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.0593,-0.7708,0>,<0,0,1>
ACTL/<-0.0593,-0.7707,0.0022>,<0,0,1>
TARG/<-0.0593,-0.7708,0>,<0,0,1>
SNAP=NO
SHOW HITS=NO
PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
THEO/<-0.2195,-0.9481,0>,<0,0,1>
ACTL/<-0.2195,-0.948,0.0025>,<0.0005395,0.0002914,0.9999998>
CONSTR/PLANE,BF,PNT8,PNT9,PNT10,PNT11,,
MOVE/POINT,NORMAL,<0.1327,-0.0915,0.3473>
PNT12 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1325,-0.1634,0.1938>,<1,0,0>
ACTL/<-0.1313,-0.1635,0.1935>,<1,0,0>
TARG/<-0.1325,-0.1634,0.1938>,<1,0,0>
SNAP=NO
SHOW HITS=NO
PNT13 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1325,-0.1644,0.0576>,<1,0,0>
ACTL/<-0.1314,-0.1644,0.0573>,<1,0,0>
TARG/<-0.1325,-0.1644,0.0576>,<1,0,0>
SNAP=NO
SHOW HITS=NO
PNT14 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1325,-0.0345,0.0595>,<1,0,0>
ACTL/<-0.1315,-0.0343,0.0594>,<1,0,0>
TARG/<-0.1325,-0.0345,0.0595>,<1,0,0>
SNAP=NO
SHOW HITS=NO
PNT15 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.1325,-0.0281,0.1753>,<1,0,0>
ACTL/<-0.1314,-0.0281,0.1751>,<1,0,0>
TARG/<-0.1325,-0.0281,0.1753>,<1,0,0>
SNAP=NO
SHOW HITS=NO
PLN3 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
THEO/<-0.1325,-0.0976,0.1215>,<1,0,0>
ACTL/<-0.1314,-0.0976,0.1213>,<0.9999997,0.0006393,-0.0003776>
CONSTR/PLANE,BF,PNT12,PNT13,PNT14,PNT15,,
MOVE/POINT,NORMAL,<-0.0619,-0.0456,0.3554>
MOVE/POINT,NORMAL,<-0.5924,-0.1321,0.3502>
PNT16 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3025,-0.1662,0.1846>,<-1,0,0>
ACTL/<-0.3017,-0.1661,0.1848>,<-1,0,0>
TARG/<-0.3025,-0.1662,0.1846>,<-1,0,0>
SNAP=NO
SHOW HITS=NO
PNT17 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3025,-0.1672,0.0594>,<-1,0,0>
ACTL/<-0.302,-0.1671,0.0596>,<-1,0,0>
TARG/<-0.3025,-0.1672,0.0594>,<-1,0,0>
SNAP=NO
SHOW HITS=NO
PNT18 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3025,-0.0324,0.0507>,<-1,0,0>
ACTL/<-0.3021,-0.0321,0.0509>,<-1,0,0>
TARG/<-0.3025,-0.0324,0.0507>,<-1,0,0>
SNAP=NO
SHOW HITS=NO
PNT19 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<-0.3025,-0.0267,0.1692>,<-1,0,0>
ACTL/<-0.3018,-0.0265,0.1695>,<-1,0,0>
TARG/<-0.3025,-0.0267,0.1692>,<-1,0,0>
SNAP=NO
SHOW HITS=NO
PLN4 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
THEO/<-0.3025,-0.0981,0.1159>,<-1,0,0>
ACTL/<-0.3019,-0.098,0.1162>,<-0.9999978,-0.0004401,0.0020574>
CONSTR/PLANE,BF,PNT16,PNT17,PNT18,PNT19,,
PLN5 =FEAT/PLANE,CARTESIAN,TRIANGLE,NO
THEO/<-0.2175,-0.0979,0.1187>,<1,0,0>
ACTL/<-0.2166,-0.0978,0.1188>,<0.9999991,0.0005397,-0.0012175>
CONSTR/PLANE,MID,PLN3,PLN4
MOVE/POINT,NORMAL,<-0.3694,-0.0699,0.6117>
MOVE/POINT,NORMAL,<5.7771,-0.1273,0.5686>
TIP/T1A90B-90, SHANKIJK=0.9999, -0.0093, -0.007, ANGLE=-84.4247
MOVE/POINT,NORMAL,<0.7509,-0.3511,0.4535>
CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<-0.1425,-0.0997,0.1388>,<1,0,0>,0.096
ACTL/<-0.1312,-0.0901,0.1416>,<1,0,0>,0.096
TARG/<-0.1425,-0.0997,0.1388>,<1,0,0>
START ANG=136.8,END ANG=496.8
ANGLE VEC=<0,-0.0487885,-0.9988091>
DIRECTION=CCW
NUMHITS=6,DEPTH=0.12,PITCH=0
SAMPLE METHOD=SAMPLE_HITS
SAMPLE HITS=1,SPACER=0.03
SHOW HITS=NO
CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
ACTL/<-0.1313,-0.0898,0.1417>,<1,0,0>,0.0963
DIRECTION=CCW
NUMHITS=6,DEPTH=0.03,PITCH=0
SHOW HITS=NO
CYL1 =FEAT/CYLINDER,CARTESIAN,IN,LEAST_SQR,NO
THEO/<-0.2175,-0.0997,0.1388>,<1,0,0>,0.096,0.09
ACTL/<-0.2064,-0.09,0.1416>,<0.9999951,0.002977,0.0009938>,0.0951 ,0.0906
CONSTR/CYLINDER,BF,CIR1,CIR2,,
LIN2 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
THEO/<-0.2625,-0.0997,0.1388>,<1,0,0>
ACTL/<-0.2518,-0.0901,0.1415>,<0.9999951,0.002977,0.0009938>
CONSTR/LINE,CAST,CYL1,0.09,DEPENDENT
DATDEF/FEATURE=PLN5,A
DATDEF/FEATURE=CYL1,B
DATDEF/FEATURE=PLN2,C
A1 =ALIGNMENT/START,RECALL:A1 MAN,LIST=YES
ALIGNMENT/LEVEL,ZPLUS,PLN2
ALIGNMENT/TRANS,ZAXIS,PLN2
ALIGNMENT/ROTATE,XPLUS,TO,CYL1,ABOUT,ZPLUS
ALIGNMENT/TRANS,YAXIS,CYL1
ALIGNMENT/TRANS,XAXIS,PLN5
ALIGNMENT/END
MOVE/POINT,NORMAL,<0.2796,-0.7424,7.7261>
LOADPROBE/0_3X10
TIP/T1A0B0, SHANKIJK=0.0052, -0.0975, 0.9952, ANGLE=-0.7085
MOVE/POINT,NORMAL,<-0.1832,-0.1093,8.7583>
MOVE/POINT,NORMAL,<-0.2331,0.097,0.6737>
SCN1 =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=NO
MEAS/SCAN
BASICSCAN/LINE,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=NO
ENDSCAN
ENDMEAS/
MOVE/POINT,NORMAL,<0.2805,0.1955,0.2546>
SCN2 =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=17,SHOW HITS=NO,SHOWALLPARAMS=NO
MEAS/SCAN
ENDSCAN
ENDMEAS/
FCFPROF1 =SURFACE PROFILE : SCN1
FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES
CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,A RROWDENSITY=100,OUTPUT=BOTH,UNITS=IN
COMPOSITE=NO,
CUSTOMIZED DRF=NO
STANDARDTYPE=ASME_Y14_5
PRIMARY DIMENSION/PROFILE OF SURFACE,0.005,<UZ>,<UTol>,B,C,<dat>
NOTE/FCFPROF1
FEATURES/SCN1,,
FCFPROF2 =SURFACE PROFILE : SCN2
COMPOSITE=NO,
CUSTOMIZED DRF=NO
SECONDARY DIMENSION/,<tol>,<dat>,<dat>,<dat>
NOTE/FCFPROF2
FEATURES/SCN2,,
by Liambo734When taking a linear closed scan on a model Pc-dmis automatically defaults to ticking the "Prob Comp" box. When I generate, then measure the...
01-09-2010, 03:03 PM -
by MrCommentAt first this was pretty cool my Scan lines showed up with a pretty rainbow colored lines (See attached). Now Im no longer fasinated by the pretty colors...
04-04-2007, 12:02 PM -
by braulioI can't find an explication for the result of several open scan lines.
I am trying to inspect the profile of several sections of the part...-
11-09-2010, 07:12 AM -
by Jim PoehlerPulling my hair out, trying to get a scan on this part. This screen grab is just the latest venture by the CMM for a linear open scan based on a cad...
07-25-2018, 08:54 AM -
Is it possible to slice a model in PC-DMIS like in Modus?
So that we scan along that path.-
01-10-2013, 11:02 PM -
