Can't find nominal tolerances
  • Can't find nominal tolerances
    New to this but here goes
    When I do a scan of multiple parts I get an error message saying Find Nominals Tolerance. Not sure where to look to change this
    thank you
    Go to your scan command in the code, press F9. The Execution tab will have your FindNoms tolerance.
      Is there a default tolerance or is it user defined. Current tolerance is 3.000
        User defined. Search through the help files for some more information, but it roughly has to do with the approximate form error of the part + approximate positional error + approximate probe radius, if I am not mistaken. What is the probe radius that you are using?
          20200508_145218_resized.jpgThis is the error I get
            What is the probe radius that you are using? Are you in IN or MM?
              0.75 mm is the radius of my probe
                Try setting the FindNoms tolerance to 1.000
                  also set it to SELECTED SURFACES ONLY otherwise it might grab non-scan surfaces instead if the part is bad enough.
                    https://www.pcdmisforum.com/forum/pc...54061-scanning
                    Post #9 and #10 shows step by step the way I do it.
