How would you create Datum B from these 4 holes
My opinion would say this an error, but as we know all prints are different and even when it goes against all rules they still dimension however they want to and its up to us to translate what they mean. Is it possible to show pictures of the other datums so we can understand and hopefully help.
- Likes 1
The two options I see are 1: Run the circles using 1 or 3 sample hits to set the actual height, construct points for each circle, then construct a plane. If that was their intent though, I would have called the place the datum. Or 2: Do the above but create a center point from the 4 points constructed at each circle.
What is being dimensioned to Datum B? If it is a true position I would lean towards option 2. They may be wanting to hold another set of circles to the Datum B circles.
I agree though, it is a bad callout.Remembering my beautiful wife Taz who's life was lost on 6-13-2020. I love you and I miss you.
Am I missing something ? Don't you guys see hole patterns called as DATUMS on a regular basis ? What the print doesnt show would have to be a locator for B. Im guessing the Ends of the part would be a profile back to B ? I can only assume ? It's a different way of thinking. Rather than 2 edges being your 0.0. the Pattern is 0.0. THink of it this way. What if the part was bolted down and the entire outside edge of part was just clearance and served no function ? Why dimension the holes to an edge of the part ? Dimension the edge of the part to the holes. And thats what we cant see on this drawing. The callout we do see is for the pattern and the perp to A.
- Likes 6
If the leader were attached to the FCF, it would be acceptable per the 2009 standard, para. 3.4.6, fig. 3-27. Patterns are acceptable datum features, in this case it would appear that, based on "usual" precedence, you would level to A then 2D best fit the pattern, rotation and translation, and that will become your rotational constraint. Only do that if the holes are programmed to the correct nominals, however.
- Likes 1
Schlag - possibly, but we both what happens if you assume something around herethought I'd just go with what was presented.
If you're using XactMeasure just create a group of the four holes, dimension the group, and call the group Datum B.AndersI
- Likes 1
Best fit rotation and origin for the hole pattern. Should work in any version of the DEMONXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
- Likes 1
Hi
I got a part with 8 holes located on a eleptical form which is called datum B.DatA is a irregular profile .its a sheet metal part if 1.9mm thickness. Datum A is a form not a flat plane.Any suggestions for aligning the part will be much appreciated.
Agree! true it could be a super **** print, but typically the datum symbol would be connected to the FCF, as RandomJerk mentioned above
by DmisDaveThe drawing shown is an update of a part we make. Before the update the two holes through the bottom (A datum surface) were the B & C Datums.
03-16-2017, 04:34 PM -
I have a Cylindrical part datum C is attached to a feature control frame with four bolt holes. Would the datum be the hole it is pointing at or the center...
11-05-2020, 09:42 AM -
by Randyawg2019 R2, Xact. B datum is a series of 20 holes, with MMB. I use a constructed set of the 20 holes to define B datum. When I use B datum in the DRF for...
03-11-2022, 02:48 PM -
by RandyawgMore of a GD&T question, but I have serious doubts on the legality of these callouts. Are they legal? Can you have "B" datum in the DRF...
12-10-2020, 08:52 AM -
by SAGIZIE6 holes are called as B-datum and position to datum A which is a plane and it says individually next to the position call out. The question is how to...
10-05-2021, 03:49 PM -
