trying to fix operators from entering blanks
  • trying to fix operators from entering blanks
    I have an issue with operators not entering any information when on comments, and I use that information as variables for file ID saving.
    I thought I have it figured out, but maybe someone can show me what I did wrong. I thought I could just
    C1_REPEAT =LABEL/
    C1 =COMMENT/INPUT,YES,FULL SCREEN=NO,
    WORK ORDER NUMBER:
    ASSIGN/INPUT_1=C1.INPUT
    IF/INPUT_1==""
    END_IF/
    THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    -riley Lawlor
    Southern California
    Aerospace CNC Machinery
    IF/INPUT_1==""
    END_IF/
    There is no action taken if it is empty?
      C1_repeat =label/
      c1 =comment/input,yes,full screen=no,
      work order number:
      If_goto/c1.input=="",goto = c1_repeat
        thts basically the same thing I already had. When the comment comes up and the operator just pushs enter without typing a value it lets them move on to the next question. I want it to keep going back tell they enter something in.
        -riley Lawlor
        Southern California
          then you need to assign it to "" before the label. It might be holding a value from previous run.
          assign/c1=""
          C1_repeat =label/
          work order number:
            ohhh, okay. let me try that. Sounds simple enough. haha
            -riley Lawlor
            Southern California
              That did not seem to work either. Im confused. Some reason in my head what I did should work.
              -riley Lawlor
              Southern California
              • neil.challinor
                neil.challinor commented
                As other people have already pointed out, the code you originally posted is missing a GOTO command - it should read as below...
                C1_REPEAT =LABEL/
                WORK ORDER NUMBER:
                IF/INPUT_1==""
                GOTO/C1_REPEAT
                END_IF/
              Yep, you're missing a GOTO command to send it back the the label you have before the question.
              You can either have a GOTO command in the IF statement, or use IF_GOTO like Matt showed.
              Applications Engineer
              Hexagon UK
                Time to break out the whip
                  Seeing a future problem... What do you do about the input comment holding the information? If the program is run then saved, when it comes in again on the next work order and the same program is ran, the operator could just hit enter and it'll have the old work order number in it. How would you fix that issue?
                  • BIGWIG7
                    BIGWIG7 commented
                    everytime we start a new program we put it in a new folder with the date and the operators initals.
                    I hate rerunning over old programs.
                  • neil.challinor
                    In the setup (F5) on the general tab, switch on "Clear Input On Execution".
                  • A-machine-insp
                    A-machine-insp commented
                    neil.challinor thanks. I knew there was a way, just wasn't sure how.
                  Try this:
                  C1_REPEAT =LABEL/
                  C1 =COMMENT/INPUT,NO,FULL SCREEN=NO,
                  WORK ORDER NUMBER:
                  IF/INPUT_1==INT("")
                  IF/Conditional value = 1
                  GOTO/C1_REPEAT
                  END_IF/
                  Or try this:
                  C1_REPEAT =LABEL/
                  WORK ORDER NUMBER:
                  IF_GOTO/INPUT_1==INT(""),GOTO = C1_REPEAT
                  While loop numbers only:
                  Use IF/INPUT_1==INT("") OR INPUT_1==STR(INPUT_1) for numbers only, IF/INPUT_1==INT("") OR INPUT_1==INT(INPUT_1) for text only and IF/INPUT_1==INT("") for numbers and text only.
                   ASSIGN/ATTEMPT_CNT=0
                  WHILE/ATTEMPT_CNT<5
                  C1_REPEAT =LABEL/
                  WORK ORDER NUMBER:
                  [B]IF/INPUT_1==INT("") OR INPUT_1==STR(INPUT_1)[/B]
                  ASSIGN/ATTEMPT_CNT=ATTEMPT_CNT+1
                  IF/ATTEMPT_CNT<5
                  Enter Work Order number
                  "Attempt "+ATTEMPT_CNT+" out of 5."
                  GOTO/C1_REPEAT
                  END_IF/
                  ELSE_IF/ATTEMPT_CNT>4
                  "Reach the maximum "+ATTEMPT_CNT+" attempts."
                  Ending Routine.
                  GOTO/ROUTINE_END
                  END_ELSEIF/
                  END_IF/
                  GOTO/ROUTINE_START
                  END_WHILE/
                  ROUTINE_START=LABEL/
                  Starting routing
                  ROUTINE_END=LABEL/
                    I think this is not complete without a loop counter, at 5 failed attempts to follow direction an escalated corrective action is then automatically initiated
                      rtlawlor
                      ​​​​​​​I would do this, very simple a clean:
                      Serial Number:
                      IF_GOTO/LEN(C1.INPUT)<1,GOTO = C1
                      • vpt.se
                        vpt.se commented
                        Curveball: What if I just hit spacebar and then OK?
                      You mean like an automated hammer will come down and bash them in the head? I LIKE IT!!!!!
                      • Douglas
                        Douglas commented
                        I was thinking of that rack mounted laser that somebody once suggested... still an empty space in rack here
                      • DAN_M
                        DAN_M commented
                        I programmed an automated hammer (see below)
                      rtlawlor
                      Below is some stuff for you to mess with.
                      You'd use V1 for your variable for your report-naming.
                      Serial Number:
                      IF_GOTO/C1.INPUT=="0",GOTO = L1
                      GOTO/L2
                      L1 =LABEL/
                      You forgot to type in a serial number!!
                      Press OK to try again or hit Cancel.
                      C2 =COMMENT/INPUT,NO,FULL SCREEN=NO,
                      Serial Number:
                      IF_GOTO/C2.INPUT=="0",GOTO = SERNOLOOP
                      GOTO/L3
                      SERNOLOOP =LABEL/
                      ASSIGN/COUNTER1=0
                      DO/
                      ASSIGN/COUNTER1=COUNTER1+1
                      C3 =COMMENT/INPUT,NO,FULL SCREEN=NO,
                      Serial Number:
                      IF_GOTO/C3.INPUT>="1",GOTO = L4
                      UNTIL/COUNTER1=="5"
                      You have failed to type in the part's serial number
                      SEVEN times.
                      Please clock out & go apply at Wal Mart.
                      GOTO/ENDPRG
                      L2 =LABEL/
                      ASSIGN/V1=C1.INPUT
                      GOTO/L5
                      L3 =LABEL/
                      ASSIGN/V1=C2.INPUT
                      GOTO/L5
                      L4 =LABEL/
                      ASSIGN/V2=C3.INPUT
                      GOTO/L5
                      L5 =LABEL/
                      ENDPRG =LABEL/
