Manipulating alignment to find the perfect part
  • Manipulating alignment to find the perfect part
    Hey guys, hope everyone is doing well.
    Here's my situation.
    i have a part, it's a rod approx. 12'' with a tricky configuration. Rod centerline is datum -A- and at the end of the rod is a drilled hole in the middle of the centerline and that is datum -C-.
    There is a profile callout at X distance from -C- and centered to -A-. So a profile .001 -A,C-.
    The profile is made during the turning of centerline of -A-. Next up is to drill -C-.
    -C- needs to be absolutely perfect. There is an alternative plane I am using as Y origin, which I am then creating an offset point to simulate -C-.
    I want to be able to offset the alignment in an attempt to find where the machine shop needs to put DAT -C- so that we can get the profile as close as possible.
    Whenever I do this, I get asked the whole "DO YOU WANT TO UPDATE COMMANDS TO NEW CS "YES" "NO" " and based on my answer it will move the results...…
    except for the profile.
    No matter what I adjust I can't get the profile results to move back and forth. The linears will move in accordance to how much I offset, but the profile results will stay the same.
    What do I need to "adjust" to move the measured profile points so that I can tell the machine shop where to place datum -C-?
    after more experimenting it seems like adjusting the theoretical location of the offset point simulating -C- is helping move the results of the profile around. Is this doing what I want it to do?
      Could you post a stripped down print? Maybe some code?
        are you sure that your profile is set to FORM & LOCATION? Form only will 'never' change based on the alignment
        • BIGWIG7
          BIGWIG7 commented
          oh yes, def form and location.
        PNT1 =FEAT/POINT,CARTESIAN
        THEO/<0,0,0>,<0,0,1>
        ACTL/<15.775,18.5535,-26.1617>,<0,0,1>
        READPOINT/
        ALIGNMENT/TRANS,XAXIS,PNT1
        ALIGNMENT/TRANS,YAXIS,PNT1
        ALIGNMENT/TRANS,ZAXIS,PNT1
        ALIGNMENT/END
        MODE/DCC
        MOVESPEED/ 300
        CLEARP/ZPLUS,0.5,ZPLUS,0,ON
        MOVE/CLEARPLANE
        CIR.349 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR
        THEO/<0,0,-0.1745>,<0,1,0>,0.349,0
        ACTL/<-0.0024,0,-0.2161>,<0,1,0>,0.3493,0
        TARG/<0,0,-0.1745>,<0,1,0>
        START ANG=0,END ANG=180
        ANGLE VEC=<-1,0,0>
        DIRECTION=CCW
        SHOW FEATURE PARAMETERS=NO
        SHOW CONTACT PARAMETERS=YES
        NUMHITS=5,DEPTH=-0.1,PITCH=0
        SAMPLE METHOD=SAMPLE_HITS
        SAMPLE HITS=0,SPACER=-0.05
        AVOIDANCE MOVE=NO,DISTANCE=0.5
        SHOW HITS=NO
        ALIGNMENT/TRANS,XAXIS,CIR.349
        ALIGNMENT/TRANS,ZAXIS,CIR.349
        ALIGNMENT/END
        MOVE/CLEARPLANE
        PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0,0,0.145>,<0,1,0>
        ACTL/<0.0001,0.0157,0.145>,<0,1,0>
        TARG/<0,0,0.145>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        A3 =ALIGNMENT/START,RECALL:A2,LIST=YES
        ALIGNMENT/TRANS,YAXIS,PNT2
        ALIGNMENT/END
        MOVE/CLEARPLANE
        Ø.550 =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,OUT,LEAST_SQR
        THEO/<0,-3,0>,<0,1,0>,0.55,2
        ACTL/<0.003,-3,-0.0085>,<-0.0008375,0.9999951,0.0030252>,0.5479,2
        TARG/<0,-3,0>,<0,1,0>
        ANGLE VEC=<1,0,0>
        DIRECTION=CW
        NUMHITS=9,NUMLEVELS=4,DEPTH=0.035,END OFFSET=0,PITCH=0
        SAMPLE HITS=0,SPACER=0.075
        AVOIDANCE MOVE=NO,DISTANCE=0.25
        SHOW HITS=NO
        A4 =ALIGNMENT/START,RECALL:A3,LIST=YES
        ALIGNMENT/LEVEL,YPLUS,Ø.550
        ALIGNMENT/TRANS,XAXIS,Ø.550
        ALIGNMENT/TRANS,ZAXIS,Ø.550
        ALIGNMENT/END
        MOVE/CLEARPLANE
        OPTIONPROBE/MAXFORCE=0.096,LOWFORCE=0.019,UPPERFORCE=0.072,TRI GGERFORCE=0.033,
        PROBEACCURACY=0.1,POSACCURACY=0.1,#RETURNDATA=10,
        RETURNSPEED=0.4,SCANPNTDENSITY=1.25,
        SCANACCELERATION=10,SCANOFFSETFORCE=0.06,
        PROBINGMODE=DFL,MANFINEPROBING=NO
        SCN1 =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=21,SHOW HITS=NO,SHOWALLPARAMS=NO
        MEAS/SCAN
        BASICSCAN/LINE,NUMBER OF HITS=21,SHOW HITS=NO,SHOWALLPARAMS=NO
        ENDSCAN
        ENDMEAS/
        MOVE/CLEARPLANE
        SCN2 =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=21,SHOW HITS=NO,SHOWALLPARAMS=NO
        MEAS/SCAN
        ENDSCAN
        ENDMEAS/
        MOVE/CLEARPLANE
        PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0,1.673,0>,<0,1,0>
        ACTL/<0.0002,1.6733,0>,<0,1,0>
        TARG/<0,1.673,0>,<0,1,0>
        SNAP=NO
        AVOIDANCE MOVE=NO,DISTANCE=0.3937
        SHOW HITS=NO
        MOVE/CLEARPLANE
        Ø.207 =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,OUT,LEAST_SQR
        THEO/<0,0,0>,<0,1,0>,0.207,1.5
        ACTL/<-0.0007,0,-0.0002>,<0.0000603,0.9999987,-0.001634>,0.207,1.5
        TARG/<0,0,0>,<0,1,0>
        ANGLE VEC=<1,0,0>
        DIRECTION=CW
        NUMHITS=7,NUMLEVELS=4,DEPTH=0.1,END OFFSET=0,PITCH=0
        SHOW HITS=NO
        MOVE/CLEARPLANE
        Ø.349 =FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,OUT,LEAST_SQR
        THEO/<0,-0.217,0>,<0,1,0>,0.349,0.15
        ACTL/<-0.0005,-0.217,-0.0003>,<-0.0003545,0.9999997,0.0007012>,0.3491,0.15
        TARG/<0,-0.217,0>,<0,1,0>
        ANGLE VEC=<1,0,0>
        DIRECTION=CW
        NUMHITS=7,NUMLEVELS=2,DEPTH=0.025,END OFFSET=0,PITCH=0
        SHOW HITS=NO
        MOVE/CLEARPLANE
        CON1 =FEAT/CONTACT/CONE/DEFAULT,CARTESIAN,OUT
        THEO/<0,-0.7196,0>,<0,-1,0>,22.6199,-0.4,0.55
        ACTL/<-0.0005,-0.7196,0>,<0.000099,-0.9999999,0.0003038>,22.41,-0.4006,0.5472
        TARG/<0,-0.7196,0>,<0,-1,0>
        ANGLE VEC=<1,0,0>
        NUMHITS=6,NUMLEVELS=3,DEPTH=0.05,END OFFSET=0
        SHOW HITS=NO
        MOVE/INCREMENT,<0,0,1>
        RECALL/ALIGNMENT,INTERNAL,A1
        MOVE/POINT,NORMAL,<0,0,0>
        RECALL/ALIGNMENT,INTERNAL,A4
        MOVE/CLEARPLANE
        PNT4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0.35,-6.217,-0.025>,<0,1,0>
        ACTL/<0.35,-6.2159,-0.025>,<0,1,0>
        TARG/<0.35,-6.217,-0.025>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        PNT6 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<0.3,-6.217,0.125>,<0,1,0>
        ACTL/<0.3002,-6.2156,0.125>,<0,1,0>
        TARG/<0.3,-6.217,0.125>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        MOVE/CLEARPLANE
        PNT7 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<-0.3,-6.217,0.125>,<0,1,0>
        ACTL/<-0.2999,-6.2156,0.125>,<0,1,0>
        TARG/<-0.3,-6.217,0.125>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        PNT5 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
        THEO/<-0.35,-6.217,-0.025>,<0,1,0>
        ACTL/<-0.3498,-6.2159,-0.025>,<0,1,0>
        TARG/<-0.35,-6.217,-0.025>,<0,1,0>
        SNAP=NO
        SHOW HITS=NO
        PLN1 =FEAT/PLANE,CARTESIAN,OUTLINE,NO
        THEO/<0,-6.217,0.05>,<0,1,0>
        ACTL/<0.0001,-6.2157,0.0501>,<0.0000444,0.9999982,-0.0019002>
        CONSTR/PLANE,BFRE,PNT4,PNT5,PNT6,PNT7,,
        OUTLIER_REMOVAL/OFF,3
        FILTER/OFF,WAVELENGTH=0
        A5 =ALIGNMENT/START,RECALL:A4,LIST=YES
        ALIGNMENT/TRANS,YAXIS,PLN1
        ALIGNMENT/END
        THEO =FEAT/POINT,CARTESIAN,YES
        THEO/<0,-0.625,0>,<0,0,1>
        ACTL/<0,-0.625,0>,<0,0,1>
        CONSTR/POINT,OFFSET,ORIGIN,0,-0.625,0
        A6 =ALIGNMENT/START,RECALL:A5,LIST=YES
        ALIGNMENT/TRANS,YAXIS,THEO
        ALIGNMENT/END
        DIM LOC1= LOCATION OF PLANE PLN1 UNITS=IN ,$
        Y 0.6250 0.0005 0.0005 0.6250 0.0000 0.0000 ----#----
        END OF DIMENSION LOC1
        DIM LOC2= LOCATION OF POINT PNT2 UNITS=IN ,$
        Y 6.8420 0.0005 0.0005 6.8412 -0.0008 0.0003 <--------
        END OF DIMENSION LOC2
        DIM LOC3= LOCATION OF POINT PNT3 UNITS=IN ,$
        Y 8.5150 0.0005 0.0005 8.5141 -0.0009 0.0004 <--------
        END OF DIMENSION LOC3
        FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV,OUTTOL,MAXMIN,
        DIM PROF1= PROFILE OF SURFACE OF SET SCN1 FORMANDLOCATION UNITS=IN ,$
        GRAPH=OFF TEXT=OFF MULT=50.00 ARROWDENSITY=100 OUTPUT=BOTH
        AX NOMINAL +TOL -TOL MEAS DEV OUTTOL MAX MIN
        M 0.0000 0.0005 0.0005 0.0020 0.0020 0.0010 0.0009 -0.0011 <---|--->
        DIM PROF2= PROFILE OF SURFACE OF SET SCN2 FORMANDLOCATION UNITS=IN ,$
        M 0.0000 0.0005 0.0005 0.0020 0.0020 0.0015 -0.0003 -0.0020 <---|----
        DIM LOC4= LOCATION OF CYLINDER Ø.550 UNITS=IN ,$
        X 0.0000 0.0002 0.0002 0.0000 0.0000 0.0000 ----#----
        Z 0.0000 0.0002 0.0002 0.0000 0.0000 0.0000 ----#----
        D 0.5500 0.0050 0.0050 0.5479 -0.0021 0.0000 --#------
        END OF DIMENSION LOC4
        DIM CYLY1= CYLINDRICITY OF CYLINDER Ø.550 UNITS=IN ,$
        GRAPH=OFF TEXT=OFF MULT=10.00 ARROWDENSITY=100 OUTPUT=BOTH
        M 0.0000 0.0005 0.0000 0.0010 0.0010 0.0005 -------->
        DIM LOC5= LOCATION OF CYLINDER Ø.207 UNITS=IN ,$
        X 0.0000 0.0005 0.0005 -0.0007 -0.0007 0.0002 <--------
        Z 0.0000 0.0005 0.0005 -0.0002 -0.0002 0.0000 --#------
        D 0.2070 0.0020 0.0020 0.2070 0.0000 0.0000 ----#----
        END OF DIMENSION LOC5
        DIM CYLY2= CYLINDRICITY OF CYLINDER Ø.207 UNITS=IN ,$
        M 0.0000 0.0005 0.0000 0.0004 0.0004 0.0000 -------#-
        DIM LOC6= LOCATION OF CYLINDER Ø.349 UNITS=IN ,$
        X 0.0000 0.0005 0.0005 -0.0005 -0.0005 0.0000 <--------
        Z 0.0000 0.0005 0.0005 -0.0003 -0.0003 0.0000 --#------
        D 0.3490 0.0005 0.0005 0.3491 0.0001 0.0000 -----#---
        END OF DIMENSION LOC6
        DIM LOC7= LOCATION OF CONE CON1 UNITS=IN ,$
        X 0.0000 0.0005 0.0005 -0.0005 -0.0005 0.0000 #--------
        Y 6.1224 0.0005 0.0005 6.1212 -0.0013 0.0008 <--------
        Z 0.0000 0.0005 0.0005 0.0000 0.0000 0.0000 ----#----
        A 22.6199 0.0000 0.0000 22.4100 -0.2099 0.2099 <--------
        L -0.4000 0.0002 0.0002 -0.4006 -0.0006 0.0004 <--------
        END OF DIMENSION LOC7
        DATDEF/FEATURE=Ø.550,A
        DATDEF/FEATURE=THEO,C
        FCFPROF1 =SURFACE PROFILE : SCN1,SCN2
        FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES
        CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=100.00, ARROWDENSITY=100,OUTPUT=BOTH,UNITS=IN
        COMPOSITE=NO,
        CUSTOMIZED DRF=NO
        STANDARDTYPE=ASME_Y14_5
        PRIMARY DIMENSION/PROFILE OF SURFACE,0.001,<UZ>,<UTol>,A,<dat>,<dat>
        NOTE/FCFPROF1
        FEATURES/SCN1,SCN2,,
        DIMINFO/FCFPROF1;ICON,DIMID,FEATID,VERT,HORIZ, ,$
        HEADINGS,GRAPH AXIS;MEAS,OUTTOL,MAXMIN, , , , , ,
        VIEWSET1 =VIEWSET/
        RECALL/VIEWSET,VIEWSET1
          SNAPSHOT1 =SNAPSHOT/
          FCFPROF2 =SURFACE PROFILE : SCN1,SCN2
          COMPOSITE=NO,
          CUSTOMIZED DRF=NO
          PRIMARY DIMENSION/PROFILE OF SURFACE,0.001,<UZ>,<UTol>,C,<dat>,<dat>
          NOTE/FCFPROF2
          DIMINFO/FCFPROF2;ICON,DIMID,FEATID,VERT,HORIZ, ,$
          VIEWSET2 =VIEWSET/
          RECALL/VIEWSET,VIEWSET2
          SNAPSHOT2 =SNAPSHOT/
          FCFPROF3 =SURFACE PROFILE : SCN1,SCN2
          CADGRAPH=BOTH,REPORTGRAPH=OFF,TEXT=OFF,MULT=100.00 ,ARROWDENSITY=100,OUTPUT=BOTH,UNITS=IN
          COMPOSITE=NO,
          CUSTOMIZED DRF=NO
          PRIMARY DIMENSION/PROFILE OF SURFACE,0.001,<UZ>,<UTol>,A,C,<dat>
          NOTE/FCFPROF3
          DIMINFO/FCFPROF3;ICON,DIMID,FEATID,VERT,HORIZ, ,$
          VIEWSET3 =VIEWSET/
          RECALL/VIEWSET,VIEWSET3
            see if the pics work
            in the above code I am able to manipulate THEO feature at Y -.625 which is simulating -C- if it were actually there.
            as I change the theoretical Y location then the profile is moving in the direction I want. This allows me to tell the machine shop that -C- needs to be "x" distance from that face in order to try and get the profile as close as possible to nominal form.
            why doesn't the profile move when I alter the actual A6 alignment? why isn't offsetting Y in the alignment doing the same thing?
              If I wanted a production aid dimension then I would just use a Constructed circle using a gauge diameter on the cone then report the axis error I wanted.
              • BIGWIG7
                BIGWIG7 commented
                how would that help determine where to put -C- ?
              • UKCMM
                UKCMM commented
                It will tell you how far out it is from your simulated datum 'C'
              • BIGWIG7
                BIGWIG7 commented
                ahhhh I see. I created an intersection circle from -A- to the cone. Seems to work the same way. Good suggestion.
              anyone else? still would like the original question answered regarding manipulating the alignment to move data points.
                I wouldn't touch this until you show <--A - B - > https://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
                Am I missing it? I see A but.....??
                and you're A|B profile is missing a BSC. or..... ????
                  it's a minimally dimensioned drawing. profile /A---B/ A starts the first arrow to the left of the pic I just missed it when I made the screen shot.
                  I think I figured out how to manipulate the scan data by moving the THEO point back and forth.
                  • sealevel
                    sealevel commented
                    whew! thought my eyes had expired. (an my comment was bassackwards... 'B' I saw, just no 'A'...). At any rate, glad you're satisfied with your manipulation
                • Sl33stak
                  Profile results question.
                  by Sl33stak
                  This is going to show everyone how little I know.
                  I have 5 profiles to check on a part. (form and location) I am checking each...
                  05-10-2007, 11:07 AM
                • PacMan23
                  Profile Gauge Check
                  by PacMan23
                  I have a part that has a profile called out to ABC and a tolerance of +,- 3mm but the part is fails when measuring on CMM. So here at work an Engineer...
                  10-19-2017, 04:05 PM
                • Jonathan S
                  Profile to datums 3.5mr2
                  by Jonathan S
                  I have a profile callout to a datum (hole). The problem is that I can't get the demon to report profile to a different alignment than what it was measured...
                  07-11-2008, 09:16 AM
                • WolfMan
                  Profile callout
                  by WolfMan
                  Is this a Legit callout, to have a profile .020 (without any datum in the FCF)
                  and this Profile .020 -A- (where the callout is to the datum...
                  04-21-2015, 09:07 AM
                • Jay_Q
                  Help with profile
                  by Jay_Q
                  We have a part that is large and twisted. It is 75 percent casting with the rest being machined surfaces. The part is checking around 10mm profile before...
                  08-19-2020, 05:04 PM
