Hey everyone, I'm trying to figure out how to create distance true position dimensions (DIM11 in this case) in PCDMIS for reporting. Is this the correct approach based on the attached screenshot of the print I'm working off of? I don't have the physical part with me to check, so I'm going off of CAD for now.
1. Create plane on the 35mm face
2. Convert to a Feature set
3. Dimension the 0.3 AB true position using Xact Measure
This is what I'm seeing in the report window after I create the above dimension:
I'm thinking that the out-of-spec dimension is just a placeholder until I get my hands on the parts. Am I approaching this correctly?
