Our CMM has lost its calibration for the disk probe. The probe was working fine then suddenly started giving false readings. The deviations would change even when running the same part without moving it. When trying to recalibrate the disk probe it would miss the calibration sphere. All other tips calibrate fine. Even tried rebuilding the probe profile with no success. Please note that the calibration sphere has not been moved and parts checked previously now show out of tolerance deviations. Any ideas?
Disk probe lost calibration
If you're still stuck after verifying that everything is tight, clean, not damaged, etc....
One of two things you could troubleshoot...
1) Your machine isn't being qualified correctly.
To use multiple probes and have them relate to one another..
-Ensure a master probe is calibrated by saying YES SPHERE HAS MOVED
-Ensure that when disc was calibrated the operator said NO SPHERE HAS NOT MOVED.
If above sequence was not followed then you're getting results from probe positions that aren't related to one another. If the disc isn't related to your master, that COULD be why its acting all funky and missing the qual sphere.
2) Probe files are corrupt.
Nothing you can do to fix besides delete and re-make the probe file.
by constadinHello all!
Please help me with this disk calibration, it is driving me nuts.
Disk Dia 4mm, 0.6 mm width.
I found...-
09-20-2022, 04:31 AM -
by David WedelI did a search for this and didnt have any luck but why is when 2 weeks ago i calibrated my disk probe (TP20X25X1.5 Disk) and it workded fine and been...
08-10-2010, 02:10 PM -
by pab39Hi,
I'm trying to calibrate a ceramic disk probe that doesn't exist in the initial list. Anyway, i selected the one that was the closest....-
11-11-2020, 01:32 PM -
by Clay_ManHi All
I am looking for a little feedback (HELP) on how to measure the spline I.D. datum B and the other feature, was thinking of using...-
03-31-2006, 03:49 PM -
by dave.hereRecently started a new job 4 B&S CMMs all running PCD two full probe racks per machine.
All machines have the calibration sphere in a fixed...-
07-17-2018, 06:49 AM -
