We have the same programs run on multiple CMM's. We would like to have our report and stats output recognize what CMM was running the program to help with quality control. Is there a way to have the program pull this info from the CMM without having any input from the operator? We can barely get them to fill in serial numbers, so there's no hope for machine name.
Variable for machine name without user input?
Are the cmms on a network ?
Maybe using "ISIOCHANNELSET" could help, not sure of this.
From core manual :
ISIOCHANNELSET
This expression takes two parameters. The first parameter indicates which I/O channel will be checked (the range of numbers that is available is based on the machine being used). The second parameter determines whether the software will query the Arm1 or Arm2 machine. If the second parameter is set to 1 (one) it will query the Arm2 controller. If the second parameter is not present (or is set to zero), then the IO Channel will query the Arm1 controller. The Arm1 controller is your only option if you are not in multiple arm mode. If an invalid probe data type, tip id, probe file name, or channel number is supplied, the expression evaluates to 0.
Example:
ASSIGN/V4=ISIOCHANNELSET(3,0)
V4 will equal 1 (evaluate to true) when the channel is set, otherwise it will equal 0 (evaluate to false).
Easiest way would be a comment at the top of the program. Only thing is you would have to remember to change them to the correct CMM #.
The way we do it so we don't have to remember to change it is a .txt file that stays on the C drive. We then have code that reads this and puts it in a tracefield. See the code pulled from one of our programs below.
Code:ASSIGN/CMMID=0 FE1 =FILE/EXISTS,C:\SETCMM.TXT IF/FE1<>1 CMN =COMMENT/INPUT,NO,FULL SCREEN=NO, 'CMM NO:' ASSIGN/SETID="CMM " + CMN.INPUT FPTA =FILE/OPEN,C:\SETCMM.TXT,WRITE FILE/WRITELINE,FPTA,SETID FILE/CLOSE,FPTA,KEEP END_IF/ ASSIGN/IDFILE="C:\SETCMM.TXT" GETCMMNO =FILE/OPEN,IDFILE,READ SETID =FILE/READ_BLOCK,GETCMMNO,5 FILE/CLOSE,GETCMMNO,KEEP
- Likes 2
by RichVPWe have been in the process of updating our CMM's and programs so that everything can run from a secured location to ensure our programs are up to date...
08-05-2016, 10:54 AM -
by WScmmHi All,
Does anyone know how to pull the CMM machine name or ID number some kind of identifier that can be pull for machine size. I have...-
06-17-2020, 09:21 AM -
by MANIKANTAI want to know what type of controller is installed to the CMM birdge type DEA machine 9.15.8
how to find the controller name installed to...-
08-26-2016, 12:11 PM -
by MikegWe just got a new CMM and I am looking for input on setting my programs up. The new CMM is a global 555 (same as our other one). I plan on adding an input...
04-27-2017, 02:33 PM -
Hey guys,
I was hoping one of you could help me with this. I want the "Part Name" field in PC-DMIS to use a variable, but I can't...-
03-31-2020, 02:46 PM -
