2019 r1 sp9
  • 2019 r1 sp9
    Here :
    https://www.wilcoxassoc.com/public/P...19_R1/SP9/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R1/SP9/x64/
    Release Notes - 2019 R1 - SP9
    • PCD-164450 - Fixed an issue where the Auto Line projection to a sample
    feature (for example, a measured plane) failed even though the vectors
    were fine.
    • PCD-183493 - Fixed a software crash that occurred when you closed the
    measurement routine after the execution of a Laser calibration program.
    • PCD-186862 - Fixed an issue where the Defined scan option in Blade
    Scan dialog box was not working when CAD equals part was not
    performed and an external alignment was recalled.
    • PCD-187553 - Fixed an issue where PC-DMIS did not update a 2D distance
    or 2D angle dimension when you inserted the WORKPLANE command.
    • PCD-187875 - Fixed an issue where the template match code was used
    incorrectly in the Probe Offset Calibration and the Pixel Size Verification of
    the Vision sensor.
    • PCD-188086 - Fixed an issue where Q-DAS Configurator was not able to
    read datum features from the Legacy True Position dimension.
    • PCD-188128 - Added the ability to add the "RANGE_" prefix to the axis
    name in the statistics (.xml) file.
    • PCD-188408 - Fixed an issue where the .dfq file displayed a positive value
    instead of a negative K-field K2112 (Lower Allowance) value for Legacy
    Profile Form and Location dimensions.
    • PCD-188448 - Fixed an issue where Q-DAS Configurator doesn't show
    nominal values of true position (X, Y, Z) in Q-DAS output files when the
    tolerances were turned off.
    • PCD-189327 - Fixed an issue where the Polish language used comma
    instead of decimal point when Q-DAS Configurator created the
    QdasData.xml file.
    • PCD-189577 - Added the ability to add the "RANGE_" prefix to the range of
    the Size dimension in Q-DAS Configurator so that the ID is not blank.
    • PCD-189631 - Fixed an issue where an invalid data message occurred for
    Laser Plane auto feature when you re-executed a measurement routine.
    • PCD-189691 - Fixed an issue where PC-DMIS was not able to output
    correct values of K8500 and K8501 for the size command in the Q-DAS
    output files.
    • PCD-189855 - Fixed an issue where Q-DAS Configurator doesn't show the
    correct number of digits after decimal for the K2022 value when read in
    from a measurement routine in inch units.
