Reporting dimensions from loop 2
  • Reporting dimensions from loop 2
    I have looked all over the forum but can't find the answer to my problem. I'm running 2 loops. The first loop moves in Y, the second loop moves over in X and repeats Y movements. The first loop reports out ok, but the second loop just repeats the dimensions from the first loop. Even on the report it shows the dimensions as being from loop 1. I've tried all different ways to report the dimensions in the second loop, but can't get it to work. Running 2019 R1, Loop Snips.docx
    Can you post the code ?
      It's on the Loop Snips doc at the end of my post.
        It's been a while since I have done real programming but you're either going to have to pass the dimension data into an array or you're going to have to dimension inside the loop.
        Systems Integrator
          Why not just dimension your features inside the loop?
            https://www.pcdmisforum.com/forum/pc...er-loops/page2
            This may help.
