I am using 2018 R1 with CAD++ currently offline and have the same issue when I am online as well. I have a part that has 5 ID counter bore features with a 30° lead in chamfer. 4 of these features are equally spaced every 90°, the fifth feature is in-between two of them and is a larger ID and chamfer. I created my fist counter bore using an adaptive cylinder spiral scan. Followed by 5 linear open scans equally spaced on the counterbore. I next copied and pasted those features 3 times for my features that are the same. When I try to create my linear scans for the 5th feature it will create the code but the ID name is blank. I am holding down the Shift and Ctrl key and drag the vector arrow to create my line element. If I try to highlight it and delete the feature. I get the message "Highlighted objects may not be cut!" I an only click undo to remover the feature I created. When I go to edit the feature I can clearly see that it has the scan ID name.
My second question is this. I don't have a problem using the linear open scan for the ID cones, but when I try to measure an OD cone the probe will crash into the part when I try to run it. I will post some code tomorrow.
