Report Loc count not working for loop
  • Report Loc count not working for loop
    I'm trying to get the report to output the count number in the loop
    keeps outputting LOC_3[1] throughout the report.
    I'm looking for LOC_3[1]....[53]
    C1 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    HOW MANY ROTATIONS?
    MOVE/CLEARPLANE
    ASSIGN/V1=C1.INPUT
    ASSIGN/V2=360/C1.INPUT
    ASSIGN/DEG_COUNT=0
    LOOP1 =LOOP/START,ID=YES,NUMBER=V1,START=1,SKIP=,
    OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=V2
    COMMENT/REPT,
    "LOCATION #3 Ø12.845 - 12.849 (RADIAL 6.4235±.001) @"+DEG_COUNT
    ASSIGN/COUNT=1
    ASSIGN/ZNOM=-9.925
    WHILE/COUNT<=53
    LOC_3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
    THEO/<6.4235,0,ZNOM>,<-1,0,0>
    ACTL/<6.4235,0,-10.185>,<-1,0,0>
    TARG/<6.4235,0,ZNOM>,<-1,0,0>
    SNAP=NO
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    AVOIDANCE MOVE=NO,DISTANCE=0.3937
    SHOW HITS=NO
    ASSIGN/COUNT=COUNT+1
    ASSIGN/ZNOM=ZNOM-.005
    END_WHILE/
    ASSIGN/COUNT=1
    ASSIGN/ZNOM=-9.925
    WHILE/COUNT<=53
    DIM LOC_3HC= LOCATION OF POINT LOC_3[COUNT] UNITS=IN ,$
    AX MEAS NOMINAL +TOL -TOL OUTTOL DEV MAX MIN
    Z -10.1850 ZNOM 0.0010 0.0010 0.0000 0.0000 -10.1850 -10.1850 -#-
    PR 6.4235 6.4235 0.0010 0.0010 0.0000 0.0000 6.4235 6.4235 -#-
    END OF DIMENSION LOC_3HC[1]
    END_WHILE/
    In your code, I don't see the loop/end...
    So the PC-DMIS reads C1.INPUT, then loop on the first while, then loop on the second while, and then go to the loop start to increment...
    Is this what you want, or count and loop1 have the same value ?
      Because you have your count=1 after the loop. You should have COUNT=0 before the loop and COUNT=COUNT+1 after the loop. In your code, you cancel out the Count+1 by putting a count=1 shortly after it.
      • CORONAXRA
        CORONAXRA commented
        i have a end_while before that count
      Loop end is further down the code, i didn't include it when i posted to the thread, i'll include now
      I'm looking for the report to read LOC_3 [1] LOC_3[2]....and so on
      Highlighted in red text
      see report attachment
      HOW MANY ROTATIONS?
      CLEARP/ZPLUS,6,ZPLUS,0,OFF
      MOVE/CLEARPLANE
      ASSIGN/V1=C1.INPUT
      ASSIGN/DEG_COUNT=0
      COMMENT/REPT,
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=4.916
      WHILE/COUNT<=65
      ACTL/<6.4235,0,4.8371>,<-1,0,0>
      SNAP=NO
      SHOW HITS=NO
      END_WHILE/
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=4.916
      WHILE/COUNT<=65
      Z 4.8371 ZNOM 0.0010 0.0010 15.0211 15.0221 4.8371 4.8371 -->
      ASSIGN/ZNOM=ZNOM+.005
      END_WHILE/
      MOVE/INCREMENT,<-0.5,0,0>
      COMMENT/REPT,
      "LOCATION #4 Ø12.725 - 12.729 (RADIAL 6.3635±.001) @"+DEG_COUNT
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=-10.25
      WHILE/COUNT<=50
      LOC_4 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
      THEO/<6.3635,0,ZNOM>,<-1,0,0>
      ACTL/<6.3635,0,4.5271>,<-1,0,0>
      TARG/<6.3635,0,ZNOM>,<-1,0,0>
      SNAP=NO
      SHOW HITS=NO
      END_WHILE/
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=-10.25
      WHILE/COUNT<=50
      DIM LOC_4HC= LOCATION OF POINT LOC_4[COUNT] UNITS=IN ,$
      Z 4.5271 ZNOM 0.0010 0.0010 15.0211 15.0221 4.5271 4.5271 -->
      PR 6.3635 6.3635 0.0010 0.0010 0.0000 0.0000 6.3635 6.3635 -#-
      END OF DIMENSION LOC_4HC
      END_WHILE/
      COMMENT/REPT,
      "LOCATION #9 Ø12.404 - 12.408 (RADIAL 6.203±.001) @"+DEG_COUNT
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=-10.95
      WHILE/COUNT<=46
      LOC_9 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
      THEO/<6.203,0,ZNOM>,<-1,0,0>
      ACTL/<6.203,0,3.8471>,<-1,0,0>
      TARG/<6.203,0,ZNOM>,<-1,0,0>
      SNAP=NO
      SHOW HITS=NO
      END_WHILE/
      ASSIGN/COUNT=1
      ASSIGN/ZNOM=-10.95
      WHILE/COUNT<=46
      DIM LOC_9HC= LOCATION OF POINT LOC_9[COUNT] UNITS=IN ,$
      Z 3.8471 ZNOM 0.0010 0.0010 15.0211 15.0221 3.8471 3.8471 -->
      PR 6.2030 6.2030 0.0010 0.0010 0.0000 0.0000 6.2030 6.2030 -#-
      END OF DIMENSION LOC_9HC
      END_WHILE/
      CLEARP/ZPLUS,5.1121,ZPLUS,15.0221,OFF
      MOVE/CLEARPLANE
      ASSIGN/DEG_COUNT=DEG_COUNT+V2
      LOOP/END
        Hi,
        When you post code use code tags.
        [C0DE]
        Code here
        [/C0DE]
        ...but with O instead of 0 (Keep it uppercase or it will convert it all to lower case which makes it difficult to read.
        HOW MANY ROTATIONS?
        MOVE/CLEARPLANE
        ASSIGN/V1=C1.INPUT
        ASSIGN/DEG_COUNT=0
        COMMENT/REPT,
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=4.916
        WHILE/COUNT<=65
        SNAP=NO
        SHOW HITS=NO
        END_WHILE/
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=4.916
        WHILE/COUNT<=65
        END_WHILE/
        COMMENT/REPT,
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=-10.25
        WHILE/COUNT<=50
        SNAP=NO
        SHOW HITS=NO
        END_WHILE/
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=-10.25
        WHILE/COUNT<=50
        END_WHILE/
        COMMENT/REPT,
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=-10.95
        WHILE/COUNT<=46
        SNAP=NO
        SHOW HITS=NO
        END_WHILE/
        ASSIGN/COUNT=1
        ASSIGN/ZNOM=-10.95
        WHILE/COUNT<=46
        END_WHILE/
        MOVE/CLEARPLANE
        LOOP/END
        Applications Engineer
        Hexagon UK
          So you want V1*53 LOC_3 and 50*V1 LOC_4 ?
          Why do you "while" twice ?
          This should work as well ?
          In your code you have 3 times ZNOM-0.005 and once ZNOM+0.005...
          ASSIGN/COUNT=1
          ASSIGN/ZNOM=4.916
          WHILE/COUNT<=65
          SNAP=NO
          SHOW HITS=NO
          END_WHILE/
            Jefman, i tried your code and still not working
            the report is not cycling in numerical order
            • JEFMAN
              JEFMAN commented
              Can you try to delete the red count above ?
            Still didnt work, i included a snippet of the report
            i want loc_3[1] to cycle down the report numerically
              Couple of questions / points to consider.
              1) Does the first While loop work correctly? I.e. does the point measurement move down as expected?
              2) You might want to consider using an assignment name other than 'COUNT' (might be a protected keyword), maybe use MYCOUNT
              3) PC-Dmis can be funny with recognising variables - you might be better doing something like this
              ASSIGN/ FEATNAME = "LOC_3" + MYCOUNT <<<<<<<<<<<<<<<<<< When you write this line type MYCOUNT first and hit enter, so PC-Dmis ask if this refers to the variable, then type the "LOC_3" + part in
              ASSIGN / FEATREF = {FEATNAME} <<<<<<<<<<<<<<<<<<<< Curly brackets are used to reference a feature (Not sure this line should be needed)
              DIM LOC_3HC= LOCATION OF POINT FEATREF UNITS=IN ,$
              Sorry but too busy to test this at present.
              Hexagon UK
              • CORONAXRA
                CORONAXRA commented
                The program runs thru good, except for the report cycle
                trying your recommendations now
              What report do you use : last executed or the other (main ?)
              • CORONAXRA
                CORONAXRA commented
                Last executed
              It wont cycle thru the program now
              this is what i entered
              also featref is red in the program after assign/
              i appreciate all the help so far
              c1 =comment/input,no,full screen=no,
              how many rotations?
              Clearp/zplus,6,zplus,0,off
              move/clearplane
              assign/v1=c1.input
              assign/v2=360/c1.input
              assign/deg_count=0
              loop1 =loop/start,id=yes,number=v1,start=1,skip=,
              offset:xaxis=0,yaxis=0,zaxis=0,angle=v2
              comment/rept,
              "location #3.01 thru 3.66 ø12.845 - 12.849 (radial 6.4235±.001) @"+deg_count
              assign/count=1
              assign/znom=4.916
              while/count<=65
              loc_3[1,1] =feat/contact/vector point/default,polar
              theo/<6.4235,0,znom>,<-1,0,0>
              actl/<6.4235,0,4.916>,<-1,0,0>
              targ/<6.4235,0,znom>,<-1,0,0>
              snap=no
              show feature parameters=no
              show contact parameters=yes
              avoidance move=no,distance=0.3937
              show hits=no
              assign/count=count+1
              assign/znom=znom+.005
              end_while/
              assign/mycount=1
              assign/znom=4.916
              while/count<=65
              assign/featname="loc_3"+mycount
              assign/featref={featname}
              dim loc_3hc= location of point featref units=in ,$
              graph=off text=off mult=10.00 output=both half angle=no
              ax meas nominal +tol -tol outtol dev max min
              z 4.9160 znom 0.0010 0.0010 0.0000 0.0000 4.9160 4.9160 -#-
              pr 6.4235 6.4235 0.0010 0.0010 0.0000 0.0000 6.4235 6.4235 -#-
              end of dimension loc_3hc
              end_while/
                Tried offline with a loop inside another one, it works fine, dimensions are shown as LOC_3[X,Y] with X number of loop2 and Y number of loop1
                Also tried with a do/until instead of While / end while, it doesn't work.
                I noticed, long time ago, that on some versions, do/until didn't work fine in loops, but loops worked fine in do/until..
                HOW MANY ROTATIONS?
                MOVE/CLEARPLANE
                ASSIGN/V1=C1.INPUT
                ASSIGN/DEG_COUNT=0
                COMMENT/REPT,
                LOOP2 =LOOP/START,ID=YES,NUMBER=65,START=1,SKIP=,
                OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0.005,ANGLE=0
                THEO/<6.4235,0,4.916>,<-1,0,0>
                TARG/<6.4235,0,4.916>,<-1,0,0>
                SNAP=NO
                SHOW HITS=NO
                DIM LOC_3HC= LOCATION OF POINT LOC_3 UNITS=IN ,$
                LOOP/END
                COMMENT/REPT,
                LOOP3 =LOOP/START,ID=YES,NUMBER=50,START=1,SKIP=,
                OFFSET:XAXIS=0,YAXIS=0,ZAXIS=-0.005,ANGLE=0
                THEO/<6.3635,0,-10.25>,<-1,0,0>
                TARG/<6.3635,0,-10.25>,<-1,0,0>
                SNAP=NO
                SHOW HITS=NO
                DIM LOC_4HC= LOCATION OF POINT LOC_4 UNITS=IN ,$
                LOOP/END
                COMMENT/REPT,
                LOOP4 =LOOP/START,ID=YES,NUMBER=46,START=1,SKIP=,
                ASSIGN/COUNT=1
                ASSIGN/ZNOM=-10.95
                WHILE/COUNT<=46
                THEO/<6.203,0,-10.95>,<-1,0,0>
                TARG/<6.203,0,-10.95>,<-1,0,0>
                SNAP=NO
                SHOW HITS=NO
                DIM LOC_9HC= LOCATION OF POINT LOC_9 UNITS=IN ,$
                LOOP/END
                MOVE/CLEARPLANE
                LOOP/END
                look here : https://www.pcdmisforum.com/forum/pc...-until-problem
                  Works great, thank you very much
                  i tried making a loop within a loop and that didnt work for me
                  maybe beacause i was using the assign/nom=nom+.005
                  might have been canceling each other out
