Attached is the project that I was talking about ans instructions on how to use the macros
Hole position as a pattern?
There needs to be 1 position symbol that is shared between top and bottom. GOOGLE COMPOSITE POSITION TOL. And what Matt said really make this an invalid callout.
Datums are required at a minimum for the upper part of the FCF, not required for the lower on a composite. As you describe it, the engineer is wanting to use composite, but did not draw it this way, as mentioned above by others. In composite tolerancing, for the upper segment, the datum reference frame created by the datums controls as many of the 6 degrees of freedom as it can and the features are measured according to this datum reference frame. For the lower segment, only the rotational degrees of freedom are constrained, and the locations are only controlled by dimensions that relate the features to themselves.
by SamsdadmattI'm trying to dimension a job I'm working on, the drawing callout is for concentricity as shown:
but i dont seem to have the option to add the modifiers:...-
09-21-2017, 03:46 AM -
by John Riggins
See the attachment.
I would like to see if other folks here agree with my interpretation of the Composite TP FCF in the attachment....-
06-03-2010, 06:44 PM -
by spierce009do I need CAD++ to get this to work? I have MR2 with Oct2010 patch.(portable) currently I have PC-DMIS CAD only (my manager forgot to put CAD++ in the...
11-11-2010, 09:54 AM -
by cvollmerHow would I measure and report this Profile #9.
2013CAD++ MR1, TP20...-
02-26-2015, 08:40 AM -
by Dave PoggiAttached PDF is a GD&T Callout on a part I am measuing. It is in Metric units. When I create the FCF as it is called out my results for the Angularity...
04-21-2009, 01:29 PM -
