During the shutdown, PC-DMIS evolve
https://www.wilcoxassoc.com/public/P...19_R2/SP5/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP5/x64/
Release Notes - 2019 R2
SP5
• PCD-161301 - Fixed an issue where the z-axis was not included when you
automatically inserted Location for a Laser circle.
• PCD-164450 - Fixed an issue where Auto Line projection to sample feature
(measured plane) failed when the vectors were fine.
• PCD-171107 - Fixed an issue where you could not extract Extended
Surface Point features when you marked the Remove outliers check box
in the Laser Auto Feature dialog box.
• PCD-179194 - Fixed an issue where PC-DMIS had displayed the Feature
failed to execute dialog box from the On Error command in automation.
• PCD-185751 - Fixed an issue where the extraction of a circle feature from
a perfect cloud created on a 20mm circle always returned a bigger
diameter value after you executed the measurement routine.
• PCD-186862 - Fixed an issue where the Defined scan option in Blade Scan
dialog box was not working when CAD equals part was not performed and
external alignment was recalled.
• PCD-187553 - Fixed an issue where PC-DMIS did not update a 2D distance
or 2D angle dimension when you inserted the WORKPLANE command.
• PCD-187875 - Fixed an issue where the template match code was used
incorrectly in the Probe Offset Calibration and Pixel Size Verification of the
Vision Sensor.
• PCD-188086 - Fixed an issue where Q-DAS Configurator was not able to
read datum features from the Legacy True Position dimension.
• PCD-188128 - Added the ability to add the "RANGE_" prefix to the axis
name in the statistics (.xml) file.
• PCD-188408 - Fixed an issue where the .dfq file displayed a positive value
instead of a negative value of K-field K2112 (Lower Allowance) for Legacy
Profile form and Location Dimensions.
• PCD-188448 - Fixed an issue where Q-DAS Configurator doesn't show
nominal values of true position (X, Y, Z) in Q-DAS output files when the
tolerances were turned off.
• PCD-189207 - Fixed an issue where the DMIS Output file (.dmo) file was
not proper when you imported the .dmi file.
• PCD-189273 - Fixed a software crash that occurred when you migrated
your measurement routine to the previous version and selected any light
settings.
• PCD-189327 - Fixed an issue where the Polish language used comma
instead of decimal point when Q-DAS Configurator created the
QdasData.xml file.
• PCD-189631 - Fixed an issue where a invalid data message occurred for
Laser Plane auto feature when you re-executed a measurement routine.
• PCD-189691 - Fixed an issue where PC-DMIS was not able to output
correct values of K8500 and K8501 for the size command in the Q-DAS
output files.
• PCD-189855 - Fixed an issue where Q-DAS Configurator doesn't show the
correct number of digits after decimal for the K2022 value when Q-DAS
Configurator reads characteristic from a measurement routine in inch
units
SP5
Vision Sensor.
settings.
QdasData.xml file.
output files.
units
