Swapping Computers Revisited
  • Swapping Computers Revisited
    Good Morning!
    IT has cobbled together a computer with more power and a video card for me. I followed the procedure that Hoedeman posted on another forum using a number of tooling balls, etc. I am going from a system running XP to one running 2000. The ball test seems to work alright from one machine to the other, provided I am using A=0 B=0 tip. My problem arises when I attempt to qualify tips on the new machine. The tip rotates and then cannot find the ball. It appears that the machine is not seeing the offsets for the other tips. It almost looks to me like the machine off 180 degrees. So if I rotate to 30>0 it looks like the machine thinks it is at 30>180.
    I am running PCDMIS CAD ++ v3.7 MR1. I know Hoedeman talked about the PCDMIS.INI file, but since I am running 3.7, it would appear that I would have to do something with this in the registry, an operation for which I am a complete ignoramous.
    Thoughts, comments, suggestions?
    Originally posted by gcunniff View Post
    Good Morning!
    CHECK the F5 setups. There is a HEAD ORIENTATION setup page for you to tell Pcdmis which way the various angles point with the head the way you have it on the machine. I'll bet that is the issue.
      Oh, by the way, it is F5 ~ PART/MACHINE, then you will see a button for PROBE HEAD ORIENTATION
        On old pc: START-PROGRAMS-PCDMIS FOR WINDOWS-SETTINGS EDITOR-EXPORT-SAVE IT TO DESKTOP
        COPY THIS FILE TO A FLOPPY
        On new pc: START-PROGRAMS-PCDMIS FOR WINDOWS-SETTINGS EDITOR-IMPORT-RECALL DAT FILE FROM FLOPPY
        or simply hit to F5 - PART/CMM (Or PART/MACHINE) -> PROBE HEAD ORIENTATION- Define the direction for A0B0 and A90B180
        HTH
        Saliha
        Either seem as you are or be as you seem.M.J.Rumi
          Hoedeman, you are da' man!
          • AuRules
            Probe Head
            by AuRules
            We have a PH10M on a G80 LK machine, and just last week change our or computer that was out of warranty, back up all tips and our programs run from the...
            03-25-2009, 04:37 PM
          • jjager
            modifying machine definition
            by jjager
            New member and new PCDMIS user.
            I sent this email to tec support two days ago and they haven’t responded yet, and I’m impatient....
            07-19-2013, 02:50 PM
          • Tested
            Lost artifact
            by Tested
            I just move one of my CMM to one of our other plants and after a brown and Sharpe calibration. I got a call that they can not get the machine to calibrate....
            10-07-2009, 12:05 PM
          • cmmspm
            Rotating a MH20i Standard
            by cmmspm
            Hi -
            I have a part up on it's side. I aligned and check everything on one side with the head at A90 B-90. Went above the part, rotated the head...
            09-14-2006, 09:05 PM
          • BWilliams
            Installing New Probe Head
            by BWilliams
            I recived a replacement probe head for my machine today and I have a question when it comes to installation. It is a TesaStar-I and it is going on a Global...
            05-14-2007, 04:39 PM
