SP25m & scanning
  • SP25m & scanning
    Global Image, 3.7mr1. When I run a part program with a probe build that has a TP20 then try to run a part program that has a probe build for scanning I get "Emergency Error" and have to press m/c start to run the program. Has anyone had this problem??
    To the Brave and the Faithful nothing is impossible
    What kind of Emergency ? Just a "Emergency Error" or "TR_FG014" "TR_FG013" ??
    What is written in Execution Mode Option window's MACHINE ERRORS and COMMAND lines?
    What you are seeing on the screen left hand side below?
    Either seem as you are or be as you seem.M.J.Rumi
      The machine error is as if the ESTOP button was pressed and the error window gives you the option of SHUTDOWN or OK. In the bottom left hand corner "Waiting for response: SHOW ESTOP" is displayed
        Does SM modules working fine? Have you ever used TP20 on this machine , or is this first time?
          It is the first time using the scanning probe. Was just informed that its a bug. The controller and the software don't like when you switch from a TP20 to a SM25-1 so the controller throws up this error.
            I think it is better call your techSup , to check the constants and dip switch configuration of the head control unit.
