Styli material - sm25
  • Styli material - sm25
    Anyone use a carbide probe tip for the styli
    PG
    PC-DMIS 2010 MR3
    B&S Global Advantage 7-10-7
    TesaStar - SP25
    Houston, TX
    Carbide shanks yes, carbide tips on a CMM, no never. Where are you finding them, are they intended for CMM use or for test indicators and contracers maybe? Carbide tips are more common on other machines/instruments in general
    • pguillory
      pguillory commented
      Sorry, I meant the shank. haha, But thanks!
    Carbide shanks are common especially among smaller tips, but stainless steel is cheaper so I use them where I can. Carbide is heavier but stiffer so for longer shanks I want it but shorter stuff like for example I use 2x10mm tips and stainless steel shank that short is rigid enough to calibrate well for me... carbide seems pointless on these.
      Silicone Nitride tips with carbide shanks here.
      EDIT: I buy from our local manufacturer Q-PLUS https://www.cmms.com/ they'll also make whatever probe you can think up.
      PcDmis 2015.1 SP10 CAD++
      Global 7-10-7 DC800S
      • pguillory
        pguillory commented
        Nice! I'll look into this. Carbide shanks seem like they would yield better results and longer life right?
      • Kp61dude!
        Kp61dude! commented
        crashing them is what normally kills them... and the only thing you can really do to avoid that is not crash. As far as the tip, it should be fine in Ruby unless you scan a bunch...you'll start to see flat spots on the ball. That's the main reason I switched to Silicone Nitride.
      • pguillory
        pguillory commented
        Ahh. gotcha. I'll definitely look into Silicon Nitride because I do scan a lot. It's Turbine Blades
      Carbide shafts, Ruby styli all the way.
      15 machines in production setting with different configurations on most of them. At least when they crash they break the shank rather than bend it!
      Except for the 1x30mm Renishaw stylus,(with a short stainless shaft) I use ITP styli (which is owned by Renishaw) with carbide shafts.
      • pguillory
        pguillory commented
        I like this! I definitely need to find a small ball with long shank combo. Around 1-1.5mm ball with a 30-40mm shank? You've had better use with Carbide?
    • Ken8282
      New styli
      by Ken8282
      I am looking to get a new styli with 4mm by 75mm carbon fiber stem. Having never used carbon fiber stems before. Is there any special care they need?
      02-25-2013, 10:05 AM
    • Paul Hintze
      probe tips
      by Paul Hintze
      where does everyone purchase replacement probe tips? last time i ordered some it took 2 1/2 months to get them in.
      06-19-2013, 01:00 PM
    • The Dude
      Styli
      by The Dude
      Where do you guys buy your styli? I am looking for a .5mm probe x 20mm (with an ML1 of 12mm) and am wondering if there is a place that y'all use
      03-11-2010, 10:43 AM
    • PCDEMON
      Probe Tip cleaning
      by PCDEMON
      We measure alot of alum parts with the same ball and angle and I noticed the probe ball gets alum deposits. Is there a safe or recommended way to remove...
      05-18-2010, 01:32 PM
    • Sl33stak
      New styli for a stand up?
      by Sl33stak
      I need to order some new styli for our Gage2000 stand up CMM. The previous dept. head used to order 4x50 ceramic shaft styli. The size is great for what...
      03-08-2006, 11:26 AM
