how come one of my datums is showing out of tolerance in my report.....
  • how come one of my datums is showing out of tolerance in my report.....
    when it is not out of tolerance?
    I'm using pcdmis 2013 and trying to report in xact
      heres a screen grab
        sorry for the spam....
        i think this is an error with xact measure.... when I report using legacy everything is "green" and in tolerance
          Exact is funky. I prefer to use legacy and just make sure Iโ€™m in the correct alignment and use best fit when needed.
          Darroll
          2018R2
          • Cumofo
            Cumofo commented
            That's been my long standing technique too.I've had to explain xactmeasure's habit of flipping axis vectors and nominals that don't reflect the basics too much. I like legacy. I have much better repeatability from the best fit algorithms when I can control the primary axis of rotation. I really like using a 2-D least square best fit,
          That dose n't happen very much if you use CAD=PART. But I do get it sometimes when using a lot of best fits with re-pierce checked. It seems that the theoreticals can be "disconnected" from the Part and CAD coordinates when best fitting.
            I have never ever ever (did I say never) use CAD = Part.
            Darroll
            2018R2
            • Schlag
              Schlag commented
              Same here !
            The Datum that shows out of tolerance does so because it has a zero tolerance. It will always show out of tolerance.
              38 meter shift in Z?
              Did you measure the datum after you leveled to the primary datum?
                CIR_P375-C
                CIR_PORT-C
                etc
                names like you're using can (not always) give PC-DMIS/Xact a bit of heartburn.
                Be safe and only use under_scores in your naming scheme.
                Also check the vectors.......
                2ยข
                  1) The MMB value for datum C is .750, you keyed in .5125 for the datum C MMB value, why? Delete the keyed in MMB for C and PC-DMIS will calculate the MMB. 2) You are referencing a circle as a primary datum, this requires sample hits.
                  Rob Jensen
                  Product Owner - GD&T
                  Metrology Software, Inc. - Hexagon Manufacturing Intelligence
