I know in measuring a hole, whos axis is on a compound angle, I have to translate to the theoretical center of the hole in X, Y, and Z, then rotate about the two appropriate axes to the correct angles. My question is, it shouldn't make any difference which angle of the compound angle is rotated first since the rotations are about a fixed point, so why do I get two different positional values depending on which angle is rotated first? Is this a problem with the software, or am I seeing something wrong conceptually? Running 3.7 MR3
Regards,
Keith
Regards,
Keith
