CAD in report with multiple different section views and features
  • CAD in report with multiple different section views and features
    Hi All,
    We're currently making (and measuring) a very complex part that, among other things, has 10 fin-like projections that other parts fasten to. I would post a screenshot, but sadly it's ITAR. These fins have a .001"/1x1 flatness tolerance that's pretty tricky to hold, so I'm analog scanning each fin fairly thoroughly. Occasionally something in the manufacturing process gets the teeniest bit out of whack, and then the flatness goes out of spec. I have the CAD graphics for the flatnesses turned on so the guys can see where the issues are; however, they can only see that if they look at the open program right after the part is run.
    I know it's possible to insert screenshots from the CAD window into the report; however, is it possible to have multiple screenshots with different section views and features turned on? The nature of the fins is such that it's not easy to see what's what without either the ability to rotate the part or show sections with only one CAD graph turned on at a time.
    Insert\Report command\analysis will put the graphics on the report
      Hi BKulpa ! Thank you. I was able to create an analysis view that way. Is there a way to make it show the CAD in the analysis view?
        Insert\Report command\screen capture
        It's based on your current graphics view. If you want specific area's, I'd suggest viewsets.
        • Mike Ruff
          Mike Ruff commented
          +1. This is exactly how I do it
        • mbatten
          mbatten commented
          Do viewsets remember cross-sections?
        • DAN_M
          DAN_M commented
          Yes, viewsets remember cross sections.
        Thank you for your thoughts, everybody. I'm able to show the arrow deviation graphics using the analysis view, and I'm able to make the CAD remember a specific view with viewsets, but the viewset always turns the arrow graphics off so I can't combine the two.
        I think the guys would be able to work with an angled view from the side that doesn't require sections etc. However, I need to use a viewset without it kicking the deviation arrows off.
        I also tried the newer "SNAPSHOT" functionality, but that also turned off the deviation arrows. The analysis views without CAD will be better than nothing, but it would be really nice to show the machinists exactly where on the part their problem is.
          Make sure you have the arrows turned on already when you define the Viewset.
          • mbatten
            mbatten commented
            I did, but it still turned them off when I recalled it.
